Replacement for NCC KZG and Teapo SM
  • Stefan Payne
    • 1267
    Hi
    I've got a MSI MS-7050 with some bulged caps. They are either NCC KZG (in the CPU VRM) and Teapo SM (all over the board).
    So I need some replacements for those...
    • 30997
    Re: Replacement for NCC KZG and Teapo SM
    i would use poly's for the kzg if they are vrm smoothing.
    the teapo, go panasonic FR
    • Stefan Payne
      • 1267
      thanks
      What about Panasonic FC?
      Ah, Reichelt.de also sells the FR Series.
      The FC are found under 'Capacitor, 2000-5000h', the FC are '5000-1000h'.
      But they don't seem to have radial polys, just SMD Polys....
        • 30997
        FC is usually more expensive than FR for some reason but worse ESR & lifespan.
        as for poly's, i'm surprised.
        there is a german brand that seems to be sold everywhere these days.
        http://katalog.we-online.de/en/pbs/b..._Kondensatoren
        • Stefan Payne
          • 1267
          Ah, thanks.
          Those FC are Low Impedance versions, the FR are Long Life versions.
          I know of 'Würth', they are a pretty big parts company, they sell everything from electric tools, parts (dowel, screws and so on). Quality is OK.
          But still: I don't really trust them for electronics because I do not know who the manufacturer of those caps are. I think they are a big 'labeling company' that let others manufacture their stuff, they just put their label on it.
          Conrad.de has many things from them. But the question of quality remains...
          Are they labeling japanese caps?
          Or are they labeling some taiwanese or even chinese caps?
          Either way:
          I don't seem to find 6,3V aluminium electrolyte caps anymore, the smallest voltage reichelt.de has is 10V...
          Not a real problem though...
          But it may be possible that the polymerse are replacing the electrolytes in the 'under 10V' area...
          • c_hegge
            • Sep 2009
            • 5219
            That board is a HP dx5150 motherboard. See http://www.hardwareinsights.com/wp/p...tually-work/3/
            I've done a full poly-mod on that board before. If you stick to similar value polies to what I used, you should be fine.
              • 30997
              i'm sure the wurth poly's are chinese,
              i dont have a problem with that - they are solid so i expect them to be what they are, not slowly dry up or boil like electrolytics.
              they are more like enhanced tantalums.
                • 30997
                that's not a full poly, you missed 7 caps
                • Stefan Payne
                  • 1267
                  Ah, OK, thanks for the input.
                  I think I'd go for the Pany FR, like you mentioned...
                  I don't want to waste too much money on this old S939 Board.
                  And it probably would only be used for surfing the internet at most....
                  So I think even with the Pany FR that sys will last a couple of years...
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
                  • chth96
                    Is there any Diode Replacement for MPG06J?
                    by chth96
                    is there any replacement for MPG06J diode?
                    https://www.vishay.com/docs/88682/mpg06.pdf
                    It is very hard to find this MPG06J diode in my place.
                    I think that replacement should have the same ratings with MPG06J, But it is impossible for me to hunt down replacement for MPG06J diode.
                    Any reply would be appreciated.
                    03-01-2024, 07:07 AM
                  • tfm
                    Drop-in replacement for STR-W6052S?
                    by tfm
                    The ma​in board of this LG washing and drying machine was damaged due to overvoltage. It is rated for 127V and was powered on 380V.
                    Inicial visual inspection revealed that only some components at the input of the SMPS were damaged:
                    Ironically, both fuses are intact. Probably the X2 cap and the bridge are also damaged. The whole board is immersed in an epoxy resin. I am removing it so I get access to the components.
                    The SMPS is built around an STR-W6052S, which is discontinued and I can't get a replacement....
                    02-16-2024, 08:29 AM
                  • CapLeaker
                    AcuRite 5 in 1 temperature sensor replacement repair
                    by CapLeaker
                    Got a new victim:
                    AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                    A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                    B: stuck at some temperature and maybe updating once in 12 hrs or so.
                    Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                    04-15-2025, 01:32 PM
