Panasonic now selling VESTEL rubbish as their own
    Lapwing, thanks for the pictures; It confirmed what I pretty much already thought, they are not at all customised. I had hoped that, perhaps Panasonic would demand a better power supply design and panel choice. But no, it looks like the same shit that you'd get from Technika or Bush, only at a premium price. The VESTEL panel (probably based on Samsung glass, but bonded & assembled by Vestel) is the same crap I saw in the cheap 18 month old Polaroid, with the terrible gamma correction which makes everything look like a shitty oil painting.
    They can't even print the back panel label with a high DPI so it looks all fuzzy.
    Originally posted by rievax_60
    I thought that PFC is mandatory now. I can't see it.
    Not for something low power like this. 75W input from the mains. I think the threshold is around 80-90W. Technically it's not required until 150W or so, but to meet the stringent third-harmonic emissions standards you need PFC.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #42
      Re: Panasonic now selling VESTEL rubbish as their own
      I have a 40" toshiba in now 16months old and almost every led backlight has failed. It seems that these types of bulbs always crack in the middle when they fail, what a helpless pos
      Picture showing the backlight array, bulbs with red dots above have failed.
        Yeah, seeing a lot of those types fail. What was that about LED TV backlights being more reliable? LOL. Seems the CCFLs are, oddly, more reliable because being passive devices they rarely fail until wear-out.
        A lifespan of 40,000 hours (to 1/2 brightness) for a CCFL backlight, with maybe 0.1% early failure of bulbs.
        vs a lifespan of 100,000 hours (to 1/2 brightness) for an LED backlight, but at a 5% early failure rate.
        Hmm, which wins? Oddly, CCFL will probably last longer on average!
          • 31055
          the led's are almost certainly being overdriven.
          a friend has converted backlit tv's using the 12v strips on a 5m roll without them failing - ironic that diy is more reliable!!!
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yeah, either that, or they have bad thermal engineering, or both.
            Like this cree LED bulb I took apart, the MCPCB that the LEDs were mounted on had a little bit of space between the heatsink and the MCPCB. There was no thermal grease either. No wonder the LEDs failed!
            Muh-soggy-knee
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              All my customers I advise to go with plasma or an older lcd that will be ccfl, seen too many failed leds absolute junk, and argos wont refund the customer when they fail
                • 31055
                argos needs to have it's ass kicked, dont they understand that under European law those tv's have a MANDATORY 2YEAR warranty???
                  Only mandatory enough if the consumer finds the receipt and knows about this. It's not widely promoted, of course, most people believe they only have 28 days to return it! I've bought plenty of TVs off guys who've lost the receipt; Had they still had the receipt, they'd have no problem.
                  In the UK, the SOGA law gives you 6 years warranty -- if you can show it is unreasonable for such a product to last. Unfortunately, it's difficult to argue with retailers about this, although not impossible, if you're patient...
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #49
                    Argos I feel sorry for because you only need to go into a store to see how many tvs are being returned.
                      • 31055
                      any idea where they go?
                      i know tesco sells returns that run to the staff at a large discount.
                      i know because i'v ended up with a lot of it for repair!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #51
                        A customer said to ke that they said they will send off the tv to a technician but I have no clue where, maybe the Vestel factory no clue ???
                          • 31055
                          more likely ebay or a skip.
                          the trade value of the tv is too low to cover transport & repair i suspect.
                            They go to companies like xsitems (they have an eBay shop) and/or get auctioned off, usually on large pallets; I've looked into buying a pallet, but it's several thousand pounds for one, and you MAY get just a bunch of smashed screens, so there's a lot of risk there.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #54
                              My mate Soltys uses digiland, if he gets one with a smashed screen they refund him for the whole tv.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #55
                                I get enough tvs to be able to survive with out buying pallets, had 5 vestels in to day and some others like a beko and umc.
                                  what, so how does that work? Buy a pallet of faulty TVs and they'll take back any smashed sets?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    I think that he keeps the tvs untill the pallet has been fully collected then they are either swaped or refunded for the tvs.
                                      That sounds too good to be true, but I'll have to have a look. Need more space though - probably next year...
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        Guys whats your thought on blaupunkt tvs? just saw local tesco selling 40in versions.
                                          Vestel or UMC shit. Avoid.
                                          • luis71
                                            PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
                                            by luis71
                                            Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
                                            I have backed up PQ,SPI,and Profile if anyone want
                                            Which usb_auto_update_??.txt can i use to dump firmware?
                                            I would be grateful if anyone could help me to find the firmware for USB recovery.
                                            11-05-2023, 06:31 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • l3emarsh
                                            panasonic vestel tv turn on alexa in service menu
                                            by l3emarsh
                                            i have a panasnic vestel tv and need to turn on alexa option using vestel software programming, using usb stck to reprogram software via tv usb port onced changed
                                            Please help me as i cant remember how to do it.
                                            all help is greatly appreciated
                                            01-02-2022, 10:50 AM
                                          • Russ17
                                            Panasonic TX-48CX400B 50" (Vestel) - Damaged COF's? Repair Possible?
                                            by Russ17
                                            Hi All,
                                            I was gifted a 50" Panasonic (Vestel Version) LCD, which the previous owner had disassembled and gave to me completely in parts, which had some failed backlight LED's.
                                            I replaced the LED's and got it working, but found some issues with the picture which I have never experienced before.
                                            Having looked on YouTube and various forums, it seems that one of the COF gate drivers has failed.
                                            None appear overheated or physically damaged, but if the gate drivers on the left side of the panel are touched with a bare hand while the set is on, the picture...
                                            10-21-2021, 01:32 PM
                                          • France_53
                                            Vestel tv, how to flip the image?
                                            by France_53
                                            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                            05-12-2024, 05:22 AM
