Cross reference
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Cross reference
    Need equivalent to 74HC541
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Cross reference
    There is no cross reference for that part but it is fairly common. I see them for 50 cents or less a piece.
      • 31284
      Re: Cross reference
      dil or smd?
      • tibd
        • Oct 2014
        • 189
        • Sweden
        Re: Cross reference
        Originally posted by stj
        dil or smd?
        smd, so20
          • 31284
          Re: Cross reference
          shouldnt be a problem from RS / Farnell etc.
          you can also use AHC version.
          • karlox
            IC UP9002p "equivalent"
            by karlox
            Good evening, colleagues.
            Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
            Any insight or cross-reference would be greatly appreciated. Thank you in advance!
            09-01-2025, 08:43 PM
          • raregtp
            Voltage regulator cross-reference
            by raregtp
            Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
            The first is:
            A1
            AS1117L-18
            B0640 25
            The second is:
            A1
            AS1117L-33
            B0640 28
            I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
            If anyone can assist...
            03-15-2020, 11:12 PM
          • jasko_jacker
            cross reference tps51285a
            by jasko_jacker
            I try to substitute the RT6575B with TPS51285A,
            it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
            12-07-2021, 01:49 PM
          • speaktorob
            Reference Nvidia GTX 980 ti - looking for a new shroud
            by speaktorob
            So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
            Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
            03-22-2024, 03:00 AM
          • connorcc2005
            Thermistor specs and cross reference
            by connorcc2005
            I'm getting some conflicting information and thought I'd toss it out to all of you for input.
            What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
            The physical diameter of the piece is 5.1mm measured with a caliper.
            Other than what you see in the pic, there is no other writing on the part.
            My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
            06-16-2022, 04:16 PM
