bad VCORE pwm in soft start
  • laoveja
    • Jan 2015
    • argentina
    Hi i have a Biostar k8m800 micro AM2.
    it doesn`t POST and only have 300mV on VCORE.
    The PWM Controller in an ISL6568 and after check vcc = 5v and enable (pin ENLL) = 1.2v i think its ok but i dont know what component could be bad. The enable pin is connected to pin 15 of ATPA01G (no datasheet).
    Theres a pin PGOOD that indicate the status of the controller. its always low but i dont know if its by an fault or its always in soft start. i dont know where could be the fault. the caps dont look bad. any idea? i really want to learn how to fix mobos and this is the hardest that i try. thanks
    PWM Controller:
    http://www.intersil.com/en/products/...s/ISL6568.html
    POWER CHECK:
    http://es.aliexpress.com/item/ATPA01...224449455.html
  • laoveja
    • Jan 2015
    • argentina
    Re: bad VCORE pwm in soft start
    PWM Controller:
    POWER CHECK:
    • cmia
      • Aug 2013
      • 37
      post some pictures please
      can a mod move this into the motherboard section please.
        master hoarder
        • May 2008
        • 12175
        I agree with cmia, post a picture of *your* motherboard here (use forums built-in feature, NOT off-site such as imageshack or whatever).
        You could still have bad caps but they might just not be showing it. From what I've seen, BioStar really liked to use Chemicon KZG capacitors on the VRM low side on some of their motherboards. If that is the case with your, a recap would be highly recommended.
        However, given the problem, it could also be a bad FET on the VRM. With the CPU removed, check the resistance between Vcore and ground and Vcore and 12V rail on 4-pin 12V CPU connector. Let us know what you get.
        • Sparkey55
          • Jan 2010
          • 1523
          I have seen OSTs on BioStar mobos also.
            master hoarder
            • May 2008
            • 12175
            Me too, but usually on the RAM and chipsets' rails.
            • master3112
              ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
              by master3112
              I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
              When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
              10-29-2024, 09:32 PM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • rex98
              Asus S530U Vcore buck controller
              by rex98
              This is ATK 1604AC i don't have any datasheet or schematic on the laptop. I couldn't find any info about the equivalent for this IC. My friend accidentally broke it while he's applying liquid metal on CPU. The liquid metal splash into the ATK IC pins and he turned it on without cleaning and now there's no vcore voltage.
              Maybe someone here know's what's the most common IC equivalent for this?...
              10-05-2023, 08:35 PM
              Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
              The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
              10-23-2024, 03:58 AM
            • Francisco.s
              CPU vcore missing in HP workstation Z2 Mini 4G
              by Francisco.s
              Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
              The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
              It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
              Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
              The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
              I wonder which circuit generates this enable...
              04-22-2024, 12:35 PM
