Rare transistor LM6852D
  • Paulo Trindade
    • Jul 2014
    • 8
    • Portugal
    Hi. I'm trying to repair a small 220V to 12V power source, where I found 2 LM6852D NPN shorted. I can't really find the same reference for sale, so I'm trying to find a replacement. I asked local shops but none could supply me with an equivalent.
    Now I've been trying to input the specs for the mosfet on online stores, but I put in VDS 400V or 450V, VGS 8 or 10V, and I get 0 results. Am I doing something wrong?
    Can you help me find a replacement reference?
    I've uploaded the spec sheet online (it was hard to find):
    https://app.box.com/s/6q9hyn6t1wurxlgacwtl
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Rare transistor LM6852D
    This is a NPN Bipolar transistor ia Darlington arrangement with a Damper Diode. Rare indeed as I don't think I've ever seen a transistor coded with LMxxxx. I usually see 2SA, 2SB, 2SC or 2SD.
    I'm guessing it is a Power Supply Regulator or Horizontal Output?
    • redwire
      • 3906
      It's an oddball transistor, only because it also has a built-in switch-off transistor, to speed turn off time.
      I would use any 600V beefier TO-220 sized part if it will fit. But I can't find any with a built-in reverse diode.
      • Paulo Trindade
        • Jul 2014
        • 8
        • Portugal
        It's a part of this power supply: https://app.box.com/s/kqp5ml16i1ubuxq6ye6k
        Pretty simple layout, and on the other side of the transformer there are just 2 white wires and two red ones (220V in, 9~12V out). Both mosfets died.
        I'm thinking I'll just open up a common 220V to 12V adapter and replace the whole board.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          These 2 transistors are shorted. With transistors with this internal arrangement they may be good and showing as bad when tested with an multimeter. Share a copy of the TV's circuit diagram and I may be able better to help you. Did you check those diodes for shorts and Resistors for open circuit?
          NOTE: the transistors are NOT mosfets (Metal Oxide Field Effect Transistors) but are Bi-polar (BCE)
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            May be use BU808DFI http://pdf1.alldatasheet.com/datashe.../BU808DFI.html
            • Paulo Trindade
              • Jul 2014
              • 8
              • Portugal
              All the other components were tested, and they are fine. All diodes, caps, and resistances measured and verified.
              Legs 1 to 2 (base to emiter I believe) are shorted on one transistor, the other has a very low resistance value (voltimeter still beeps).
              Edit: These were tested outside, I pulled them out before I tested them.
              It's not a power source for a TV. It's just a simple converter to feed a 12V fan.
              • Paulo Trindade
                • Jul 2014
                • 8
                • Portugal
                Originally posted by kasfamily
                Those specs are a bit different. Are you sure they will work on that circuit?
                  LM6852 is not DARLINGTON type, BU808DFI is DARLINGTON.
                  • kasfamily
                    • Aug 2014
                    • 765
                    • Russia
                    BU808DFI use in horizontal output tv. Show the whole scheme
                    • redwire
                      • 3906
                      That looks like a cheapola electronic transformer for 12V halogen lamps, like this circuit: ST Microelectronics App Note 3902
                      Suggest BUL38D or BUL39D which are bigger TO-220 package, but common.
                      • Paulo Trindade
                        • Jul 2014
                        • 8
                        • Portugal
                        Here's the whole board (notice the extra 4 diodes on the out wire).
                        • Paulo Trindade
                          • Jul 2014
                          • 8
                          • Portugal
                          I believe you are right. This board is similar to the ones on the lamps, and those transistors you point out might do the trick.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Since this Power Supply is for a fan and not to supply power to work the TV I would suggest replacing the entire thing with one of those self contained units. Cut out the jack and connect the +ve and-ve directly to the fan.
                            • Paulo Trindade
                              • Jul 2014
                              • 8
                              • Portugal
                              Hi, I did that ealier today. I might eventually try to fix the original one, but for now that was clearly the easiest way to get it working.
                              Thanks to everyone who expressed their opinion
                              • erichgamba
                                • Feb 2015
                                • philippines
                                In a CFL bulb I replaced the LM6852D with a BLD123D and it works.
                                Link to BLD123D data-sheet
                                • nunofcc
                                  Logitech G29 Help request to find smd transistor reference.
                                  by nunofcc
                                  Good night,
                                  I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
                                  Thank you for your help....
                                  10-04-2020, 01:59 PM
                                • Francesc V.
                                  Diode marked as "E57".........not able to find it by reference
                                  by Francesc V.
                                  Hi:
                                  I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                                  I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                                  It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                                  Any idea? it's a 6.6V zener?
                                  06-14-2025, 09:56 AM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • everell
                                  EVGA 500 watt with fan twitch
                                  by everell
                                  This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It...
                                  09-15-2022, 05:50 PM
                                • Francesc V.
                                  Dell dockstation WD15 is dead
                                  by Francesc V.
                                  Hi:
                                  A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                  Here are the findings, followed by good pictures. :-)
                                  When pluged in, LED3 glows
                                  Measuring some voltage in the circuit.
                                  Inductors
                                  - PL202 has 5V
                                  - PL201 has 3.3V
                                  - PL300 has 1V
                                  V. Regulators
                                  - UT30 has 19v as input and 6V as output. It seems ok.
                                  - UT27 (same reference as UT30, has no input/output voltage).
                                  Thermal find...
                                  07-09-2025, 12:12 AM
