TV recommendations
  • Theprince
    • Oct 2014
    TV recommendations
    So, I've found myself in the market for about a 60" 3d TV that won't crap out on me in a few years ... any recommendations? Reliability and display quality (I'm a fan of deep blacks esp) are priority, I'll be connecting it to a sound system most likely so less concern there.
    • 31137
    Re: TV recommendations
    good luck!
      Try getting a ex-stock Panasonic VT or ZT series plasma panel, available up to 65". You won't regret it. (About $2,200.)
      If your budget doesn't extend quite as far as that, a Samsung 64" H5000 plasma (deepest blacks but PenTile display matrix) or 60/64" F8500 plasma (deep blacks) may be an option. They're available for about $1300 and $2000 respectively.
      You could also consider an LG 55" OLED but they are about $2000. And also only available with a stupid curve in the screen. Infinite black level and piercing bright display creates incredible viewing quality. Reliability is completely unknown, so I'd definitely buy an additional warranty.
      You can also look into getting a USED Pioneer 9G Kuro. The US model 60" PDP-6020FD is widely regarded in the industry as the best TV ever made (even modern commercially available TVs have not surpassed it with the sole exception of the 55" OLEDs.) It is 6 years old today. I have a Euro model 50" 9G Kuro on my wall. It's just a completely different viewing experience. Seriously, nothing compares to it. No 3D support though; I don't like 3D so that's fine for me.
      Do not buy a large screen LED-LCD TV. In my opinion it's a world of disappointment. The picture is rubbish on such a large screen. It may be bright but there is no low level image contrast. LED-LCD is best for smaller screens, 40" and below. 4K UHD is also nothing special, so I wouldn't worry about missing out on that.
      The worst I saw was a 90" Sharp LED-LCD in Costco. And it was only 1080p! You could see the pixels on it from about 10 foot away. And they wanted £3,600 for it! (About $5,000) What a rip off! If you want a screen that big, get a bloody projector!
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • magconpres
        Samsung PN50A550S1FXZA black areas are sometimes a deep red
        by magconpres
        Hi -
        First, thanks to everyone on this forum that provides info. I have the power cycling problem that is well covered in other threads and have been able to trouble shoot it enough using info from this forum to isolate the problem to the main board, and suspect I have the capacitor problem that has been covered so well in other posts.
        However, since I have the TV opened up, I thought I'd try to ix another problem I've been living with for a while.
        In areas of scenes that are completely black I sometimes get a deep red instead of black. It's a very...
        11-26-2022, 10:07 AM
      • Perry Babin
        How do organic polymer caps compare to liquid electrolytic for reliability
        by Perry Babin
        I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
        If not organic polymer, what would be the caps that could take the most abuse?
        08-18-2025, 04:04 PM
      • _AcE_
        JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
        by _AcE_
        I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
        There's no physical damage...
        08-10-2025, 09:27 AM
      • caprider
        Recommendations of quality soldering station and (separate) hot air station
        by caprider
        Hey,
        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
        I now have a TS100 and some soldering irons and looking for some better tools.
        1. Soldering station, budget around 200-240€
        JBC BT-2BWA seems to be a good product in the budget.
        2. Hot air station, budget around 200€
        Up to now I've found ATTEN ST-862D to be a good option....
        01-15-2022, 02:05 AM
