Need help identifying a misterious appliance
  • kotel studios
    • Dec 2024
    • 200
    • Poland
    Hi
    Hopefully this went in the correct forum.
    Going through my junk I found whatever this thing is (see attachments).
    I do not what exactly it is, my guess is either some ethernet appliance or a garage door opener.
    Got it from germany, so maybe that'll help with something.
    It has:
    A hahn Prim transformer (with 2x9VA and 2x5VA outputs, 230V input)
    A diode rectifier connected to the outputs of said transformer
    PIC16F628X-20/P
    Philips TDA85521
    TPIC6C596
    ST 74HC597
    2x MAX487X
    Microchip technology 12C508A
    4x RJ45 (my-net 1/2; RS-232 Dig In; my-remote)
    1x RJ11 (Audio IN)
    Anybody more specialized than me who could ID what this thingmabob?
  • truclacicr
    • Apr 2019
    • 356
    • australia
    If you have an audio input, one would expect an audio output.
    The "Philips TDA85521" chip appears to be TDA8552T:
    https://www.nxp.com/docs/en/data-sheet/TDA8552T_TS.pdf
    Max487 is an RS-485/RS-422 Transceiver:
    https://www.analog.com/media/en/tech...487-MAX491.pdf
    • R_J
      • 9624
      Contact oemsecrets, i'm sure they can help
      • kotel studios
        • Dec 2024
        • 200
        • Poland
        Aren't they used for comparing individual electronic components from different distributors? I highly doubt they could even ID such mysterious equipment from before ~2005...
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          Not necessarily, it could be just for a sound-activated switch or something.
          I'm wildly guessing some kind of home automation controller, it has 3 relays for switching things, and inputs that could be connected to various other systems.
          -David VanHorn
          • magneh
            Transformer Hahn 230V 20v 6va
            by magneh
            Hello all.
            Not very familiar with transformers and did not find the datasheet for this one.
            Would these resistance values from Pimary and secondary normal? (check photo in red)
            Maybe someone with more experience can help me here
            Appreciate
            04-25-2025, 03:57 AM
          • learnmore
            Help choosing replacement transformer for Levoit 600S SMPS
            by learnmore
            Hello Community,
            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
            Peace
            LM...
            11-04-2025, 09:35 AM
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
