Internal Speaker for DESKTOP
  • wan901
    • Jun 2007
    • 69
    Guys i thinking to made an internal speaker ...Just now i try connect it on Frontpanel Audio connector Left_out to Positive (spk) , GND to Negative (spk) ...sound came out but very soft like headphone.....can i made it loud using the volume controller added of the center wire of Left_out and Positive(spk)..... or there is any great idea u guys had.... ^_^ hope u guys helping me out.,....
  • Rainbow
    • Aug 2005
    • 1371
    Re: Internal Speaker for DESKTOP
    The output signal is line level - you need an amplifier.
    • wan901
      • Jun 2007
      • 69
      Rainbow do you have the board diagram....so i can create it/././/
      • Logistics
        • Apr 2007
        • 721
        PC speakers are not meant to be used with a normal audio amplifier. Google it or check Wikipedia.
        Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        • twistedbottlecap10
          • Aug 2006
          • 42
          Simplest Way
          For beeps only
          • shadow
            • Feb 2007
            • 732
            From what I can understand, you want to use your normal speakers as an internal PC speaker? In that case you can directly connect the internal speaker header on your motherboard to another header on your soundcard. If you use a built in soundcard on the motherboard, then you have to connect it to one of the audio connectors on the motherboard.
            On very old soundcards, there was a special input for a PC Speaker I believe. However now I believe that those connectors have disappeared. Therefore I would connect it to the auxiliary input. With this arrangement, your main external speakers will be used as a PC Speaker as well. And it should be amplified by the sound card.
            Hopefully that would work out.
            Good luck!
            Edit: Found some nice illustrations of the audio connectors on a motherboard as well as on a soundcard.
            These were taken from: here
            • starfury1
              • May 2006
              • 1256
              I guess using the term "Internal speaker" is confusing the issue slightly
              From what you state above it seems you are using the "line out" of the case, which when connected is meant to go to a pair of "Amplified" speakers or together with the mic input for headset setup for Skype etc
              The term is confusing cause the the PC does have on the MB and case normally an "internal speaker"
              (not that iv'e thought about it much but logistics is right not its purpose in life "internal pc speaker")
              Its probably no longer the piddly little speaker and more likely what TBC10 has shown...
              So I gather you want to put a speaker inside the case for Audio output?
              Bear in mind its normally stereo output line level so you would only get one channel
              (although there are safe ways to you can mix them)
              As Rainbow said its "line level" and needs to be amplified up for the speaker.
              TBC10 is probably the easiest way,
              get a pre built small audio amp.
              Find one that works on 12 Volts DC, use the computer PSU to power it.
              make sure it isnt going to flop around in the case in anyway.
              If you really want to build one there are heaps of circuits out there for small audio amps, using audio power amp ic etc..google is your friend
              not so sure id want a speaker pounding away in the box but each to there own.
              Better me thinks external speakers But the again not really sure of your application for it either
              HTH
              Cheers
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • Rainbow
                • Aug 2005
                • 1371
                You can use a tiny single-chip amplifier - like LM386 or something like that. They're sometimes intergrated on older mainboards with AC97 sound.
                • linuxguru
                  • Apr 2005
                  • 1564
                  As shadow mentioned, older sound cards (ISA, PCI) with an on-board amplifier for use with external, non-amplified speakers often had a 2- or 4-pin header on the card, into which you could directly plug in the internal PC speaker. The sound quality wasn't great, but it was no different from internal speakers in laptops, which are usually quite audible. The main issue is that the internal speaker is not baffle-mounted, so it's probably not going to be good enough for music/movies.
                  With on-board AC97 decoders and external amplified speakers, the on-board audio amplifier has mostly vanished in present day audio cards as well as mobos. In those cases, you'll have to hack up your own audio amp with an LM386, TEA2025 or similar.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    Since he mentions the front panel audio connector, I think what he is trying to do is hook the case speaker/buzzer to the onboard sound output pins, so that the onboard AC97 audio can be heard directly from the case without using external speakers. I don't think he is trying to amplify the PC speaker/buzzer output...
                    • linuxguru
                      • Apr 2005
                      • 1564
                      Yes, but the on-board AC97 decoded audio is high-impedance line-level and can't drive anything with an impedance below about 32 ohms effectively. There has to be an intervening amp to be able to drive an 8 ohm speaker effectively. This used to be present on old ISA cards like the Aztec sound galaxy or similar, which could drive non-amplified low-impedance speaker loads, including the internal speaker. However, that's usually no longer an option with the integrated sound on the mobo.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        They make speaker boxes that fit into a CD drive bay.
                        Usually don't cost much if you shop around. ($10 on sale. Usually $15 and up.)
                        I have some to reduce the desk clutter (no more speakers on the desk) on work systems where I don't care about the quality of the sound as long as it works.
                        Even if you don't wanna use it in a CD bay if you take it apart you'd have a pair of speakers, the amp, and the cables to connect to your existing jacks or to the motherboard. (Connections will depend on which speaker box you get.)
                        ONE possible problem.
                        - Hi freq electronics don't do so well in fluctuating magnetic fields. Make sure you use magnetically shielded speakers or you may screw up your systems function.
                        Not the same but related:
                        I put bigger speakers in my garage boom box so they don't give out to distortion before the amplifier reaches it's limits as the original speakers did.
                        (Changed the cheap 10 watt single cones to better 40 watt dual cones.).
                        In general it worked out great. I can crank it and the speakers never loose quality as far up as the amp will go. - Except, If I crank it over 2/3 the way with a CD going the speaker vibrations will knock the CD off the track. (But 2/3 is more than I got before the old speakers sounded like crap,,, and it's not a problem with the radio at all.)
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          I'm taking his meaning to be he wants his stereo speakers inside the box.
                          Could be wrong...
                          - Dr Seuss
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            yeah i think so too. boom box computer case
                            bingo
                            one other thing, even if there is two speakers installed in a case, its still gonna practically be mono....yuk. need at least 1m separation between L+R to get nice stereo.
                            it would be cool though to build a quality headphone amp in a drive bay
                              HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-12-2024, 02:30 PM
                              Intel Core i7-900 Desktop Processor Extreme Edition Series Datasheet
                              The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are intended for high performance high-end desktop, Uni-processor (UP) server, and workstation systems. Several architectural and microarchitectural enhancements have been added to this processor including four processor cores in the processor package and increased shared cache.
                              The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are the first desktop multi-core processor to implement key new technologies:
                              10-23-2024, 02:56 AM
                              HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) Slimline i5-6400T Specification for Upgrade or Repair
                              This specification for the HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 260-p025il (ENERGY STAR) boardview and Slimline Slimline Desktop - 260-p025il (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                              09-12-2024, 03:44 PM
                              HP EliteDesk EliteDesk 800 65W G2 Desktop Mini PC (ENERGY STAR) EliteDesk 800 i5-6500T Specification for Upgrade or Repair
                              This specification for the HP EliteDesk EliteDesk 800 65W G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 800 65W G2 Desktop Mini PC (ENERGY STAR) boardview and EliteDesk EliteDesk 800 65W G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                              HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                              This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
