Weirdly specific reboots on a TrigKey S5 that seem to be power supply related.
  • spleenharvester
    • Mar 2010
    • 921
    I have two of these mini PCs: TrigKey S5 with Ryzen 5700U, 32GB RAM, 1TB NVMe SSD, Win11 Pro. They work very well for most uses. They are powered by a HuntKey 19V 4.74A brick with a standard DC5525 tip, which feels decently heavy.
    When the brick is connected to the system through a 1 meter DC female-male extension cord (18AWG so decently thick), the system will black screen and reboot when multiple objects are sliced simultaneously in PrusaSlicer. One object is OK. Literally any other activity on the PC is OK. It is just this one specific thing that causes a reboot. I tried running HWInfo on a 20ms interval of >250 parameters and found nothing abnormal recorded at the time of the reboot. No BSoD, nothing logged in event viewer. Even Prime95 and OCCT cannot induce a reboot.
    Take the 1 meter extension cord out, problem goes away. Utterly bizarre but completely reproduceable. The same thing happens on both PCs and their power supplies so it is not a unit specific fault. However, if you replace the power supplies with a Lenovo 20V 3.25A brick, the problem goes away, regardless of whether the extension cord is attached. At idle both the Lenovo brick and the Huntkey bricks sit at similar voltage. Haven't checked under load.
    I know the simple fix is "replace with a better supply" and I will probably end up doing that, but I am curious as to what is going on here. Is there an LC filter missing in these HuntKey supplies I wonder?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Shoving a 220uF electrolytic low-ESR cap across the DC jack input appears to have fixed this. Not very surprising as the board seems a bit devoid of decoupling caps in that area.
    It also seems to have solved an issue I was having where playing audio through the inbuilt speakers on my monitor made the input flicker
      • 31305
      the original psu is 18v, the lenovo is 20v so volt-drop across the extension will be less noticeable.
      barrel jacks arent really rated for more than a couple of amps unless designed for it and usually coloured yellow.
      do the connectors get warm?
      • spleenharvester
        • Mar 2010
        • 921
        Nah connectors don't get warm at all, even after Prime95. As an aside, barrels seem to vary in quality - I have one on 18AWG cable on my ebike that carries 210W and only gets slightly warm - tried a different cable and it melted lol
        • spleenharvester
          • Mar 2010
          • 921
          It's started doing it again, but with different triggers. This time opening Excel seems to set it off. Not really sure what to try now, RC filter possibly?
          • truclacicr
            • Apr 2019
            • 356
            • australia
            Maybe the supply doesn't handle big load changes very well. Can you see what happens if you switch on an additional 1A or 2A load while the system is idling? For example, a bank of dummy load resistors of sufficient wattage might provoke the fault. Alternatively, the element in a 2200W 240V electric jug has a resistance of 26 ohms. That would draw about 0.8A from 20V.
            • spleenharvester
              • Mar 2010
              • 921
              Haven't tested this yet but I was running HWInfo logging at 20ms and none of the voltages from +19V down to vcore drop or spike in the last logging event, so whatever's happening seems to be happening very suddenly
              Next I removed the capacitor I originally fitted and was able to replicate the original fault of it rebooting during PrusaSlicer slicing immediately so it does seem to be causative. I then fitted a proper LC filter inline with the DC jack and the problem went away again, touch wood no reboots since. If it happens again I think I will try a +20V adapter. I do remember running it with an extension off a 20V Asus ROG power supply some time ago and it was OK
                Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                09-06-2024, 08:58 AM
              • spleenharvester
                GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                by spleenharvester
                I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                07-08-2025, 06:02 PM
              • UADmytro
                Lenovo T14 Gen1 i7 10  nm-C931 (brick)
                by UADmytro
                Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
                When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
                I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
                03-23-2025, 03:45 AM
              • Track4207
                Hisense H50N5300UK reboots when showing full red images
                by Track4207
                Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                What happens:
                • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                • The problem image is displayed very briefly, then the
                08-30-2023, 11:58 AM
