Is “Tablo DVR Device” a good option for cable tv box service need find a better service option
    • Jul 2011
    • 6070
    Lately I have been having cable tv box issues that seem to be resolved for the moment but I am getting tired of system upgrades that are increasingly taking longer to make them to work correctly and paying a premium amount of money for this service unacceptable the aggregation for the last month
    Here is a link for one
    https://www.amazon.com/Tablo-4-Tuner...71&sr=8-1&th=1
    Yes I know that it is severe based system and I know what that means I do not care because I know that I am being watched by the government and corporate America anyway
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8354
    I don’t sub to anything. All I got is internet, OTA, FTA and give a sh*t about pay TV. Not shelling out $$$ to watch commercials without an end.
      • Jul 2011
      • 6070
      This device you do not have a subscription you just have to buy the device
      The reason I am after a DVR that I can record with is sometimes I am at work when the program starts or it finishes before I get home and over the internet streaming services do not allow you start from the beginning again or watch it when you have time
      How I know this is when I have no cable tv service because the system in my neighborhood has issues I have had use cable tv streaming services which is okay but not perfect unfortunately
      There are only a few programs that fall into this category this is why I pay around $20.00 months for this feature
      I need to find a cheaper way to do my tv watching when I decide to slow down and not work more than 24 hours a week probably need to make this decision by the first of next year
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Eric D.
        Sharp LC-60LE810UN Lamp error
        by Eric D.
        Hello everyone!
        I just acquired a Sharp Aquos for free.
        When I plug it in, it will try to power on, but it fails.
        The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
        I did a bit of research and did what I found could be the possible issues;
        I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
        I also tested the leads going into the psu board from the wall connector; I get 120V.
        I disconnected...
        01-18-2025, 05:14 PM
      • sohail5307
        I need how to open this Dell service menu option in dell latitude e6420
        by sohail5307
        I need to open service menu of Dell laptops like image in attachment
        Ignore my English
        I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
        01-13-2023, 05:56 AM
