Looking for replacement 6.3v 1000uf mobo caps
  • vario
    • Aug 2014
    • 8
    6.3v 1000uf 105*C OST RLP / case size: 8x12 / impedance: .013 / ripple 555
    I used this data sheet to find impedence and ripple. Caps on the mobo only show 6.3v 1000uf OST RLP on them. They are 8x12.
    Can anyone suggest a replacement, I am looking at digikey but there isn't anything that matches those specs.
    I am coming up blank.
    Please help!
    Thank you.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Looking for replacement 6.3v 1000uf mobo caps
    what about these if you can manage an extra mm high
    https://www.badcaps.net/store/produc...roducts_id=131
    • vario
      • Aug 2014
      • 8
      extra height is no problem thank you for the link. I will see if anyone else weighs in, and if no objection this will hopefully work.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        just go ahead and use them.
        • mrsith
          Dell G3 17 3779 - no display after mobo replacement
          by mrsith
          Hi guys,
          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
          04-30-2023, 05:11 AM
        • omon
          Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
          by omon
          I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
          This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
          I'm attaching the pictures of the bad cap.
          Thank you so much!...
          04-28-2021, 05:43 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
