19v accidentally applied to 12v PCB/board
This topic has been answered.
  • stormy1777
    • Oct 2015
    • 138
    Friends,
    It appears I've accidentally applied 19VDC to a PCB that should only run 12VDC.
    The board now does not power on, even with 12VDC..
    Using a thermal camera shows entire board remains COLD except one component (near power plug) that heats to 120C and higher!!
    Suspected component is marked with "T" (slanted) and "BE", think/hope it is some kind of fuse, in photo just ABOVE the green power terminals and LEFT of the 16V capacitor (on right of photo)
    Interesting part is measuring continuity across that component shows 0-reistance and a BEEP, also same thing happens across the green plastic wire power terminals (bottom of photo).. which is not what i'd expect from a FUSE, as it would CUT power and not ALLOW it to flow...
    So, now writing/thinking... maybe the allowing of current causes the heating, and that's not a FUSE, but a DIODE that is supposed to BLOCK flow, but it got "blown" and now causes a "short - circuit"...
    Now question how to proceed, I have no way to know the exact type/size of Diode.. what if.... I just REMOVE it?? could that cause the circuit to start working again? since it will eliminate the short-circuit and "open up" the board to get power...
    I do not know the board vendor or type it is part of a no-name network/switch.
  • Answer selected by stormy1777 at 07-31-2025, 01:41 AM.
    stormy1777
    • Oct 2015
    • 138
    Thanks DEAR friend - before seeing your post, could NOT resist the temptation!!
    took soldering iron, removed one side came clean, other side did not heat enough i didn't want to harm other component, so it got "ripped" a little, and device is back fully operational.. incredible!!!
    thanks... never realized diode acts as a fuse learn something new everyday!!
    • stormy1777
      • Oct 2015
      • 138
      closeup , the heated component is marked "BE" - suspect it is a diode! very tempted to remove entirely, any thoughts welcomed!
      • CapLeaker
        Leaking Member
        • 8146
        Probably a TVS diode that has a certain voltage rating. If it exceeds the voltage it goes short. Yes if you take that diode out, it should work again, just without protection. The code BE is a Vishay SMBG12CA or an SMAJ12A
        https://www.mouser.ca/ProductDetail/...2BE8RaAQ%3D%3D
        point is: it’s a TVS.
        • stormy1777
          • Oct 2015
          • 138
          • CapLeaker
            Leaking Member
            • 8146
            No. It doesn't act as a fuse. It just shorts out the voltage rail to ground. It is there to protect the circuit from over voltage condition.
            • stormy1777
              • Oct 2015
              • 138
              What is meant they acted similarly, from a FUNCTIONAL point of view (circuit protection), fuse disconnects wire, whereas diode "connected" (short circuit).. always thought only fuse can protect circuit, by cutting power, here, a short-circuit did the trick..
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                It's not functionally equivalent either.
                A fuse is ultimately used to protect against fire, basically. It is not designed to save the circuit. It is designed for your safety.
                The diode here is used as what is called an "overvoltage crowbar" and IS a form of circuit protection.
                It is not a fuse, and it does not work the same way, nor for the same reasons.
                -David VanHorn
                • stormy1777
                  • Oct 2015
                  • 138
                  Right, I see..
                  nothing personal really - the quantum continues to interact with itself..
                  Seems like over-complicating terminology and usage cases, there are many types of fuses and diodes.. sure..
                  but to claim fuses do not protect a circuit is a bit stretching IMO...
                  At least wikipedia's first sentence needs re-written:
                  https://en.wikipedia.org/wiki/Fuse_(electrical)
                  "...operates to provide overcurrent protection of an electrical circuit"
                  Same mistakes are carried over to AI-overview:
                  In an era when even definition of Bread (soft sponge sold in plastic bags) is not clear, possibly electrical components or other elements are not clear
                  As some say...if you can't convince them, confuse them
                  Suggest to close this thread and let each continue their path of (self) discovery and should they choose to pursue grammar or other philosophical or electrical journeys to continue in other more focused/dedicated threads (from reading, seems like that's a long-running debate, on the "exact" definition of "bread" or "fuse" (protect wire or circuit, etc.)
                  do good.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4953
                    • New Zealand
                    Right, I see..
                    Okay sure, yes, they do protect a circuit, technically, but ultimately, why? As you said, over current... What is the resulting effect of over current?
                    (Hint: things getting too hot... which leads to burning... Which leads to fire)
                    -David VanHorn
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                      by sam_sam_sam
                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                      Found shorted diodes on main controller relays there are 3 of them that...
                      01-07-2023, 05:43 PM
                      Tankless hot water heater controller board not powering up when power is applied
                      by sam_sam_sam
                      I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                      I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                      However I would like to know if I could figure what happened to this controller board if possible
                      Tomorrow I will take some better pictures of both side of both boards
                      The...
                      12-09-2022, 09:14 PM
