Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
  • shamsudeen
    • Apr 2020
    • 4
    • India
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply.
    • 31278
    i dont see an issue,
    laptop chargers are shit SMPS units anyway.
      • Jul 2011
      • 6070
      I have one question about doing this what about laptop computers that have a special center pin in the power jack that is required or you will get an power supply error how are you going to do deal with this I am very interested in this answer
      • m1ch43lzm
        • Mar 2019
        • 1022
        • Peru
        Search for "universal laptop charger tips", you'll find a set for several brands, they accept a standard 5.5x2.1mm barrel plug at the input
        Those work for the "regular" laptops as the ID pin is set for 65W or 90W, at least on the ones I got for HP, Dell, Lenovo square plug
        For gaming laptops that's another story, you can probably take the cable from a dead charger and mimic the resistor inside the charger for HP/Lenovo, or program an 1-wire EEPROM for Dell with the correct ID for a 230W charger or something like that
        EDIT: Found a project on github for the Dell charger emulator with an ATTINY85
        https://github.com/KivApple/dell-charger-emulator
        EDIT2: I use a linear 30V 5A PSU, for injecting voltage into a shorted rail
        Haven't tested how a bench SMPS reacts to that, if it has short circuit protection it won't work for that purpose, unless the SCP can disabled by a switch (the PSU works in constant current mode, as set by the current limit, dropping the voltage while pushing current through the short circuit)
          • Jul 2011
          • 6070
          I think ideally you would want a switching power supply that voltage and current that are control able not just voltage as far as simulation the control pin was my thought as well the ones that have the erom pin is hole another story I not sure the best way to work around that one
          The only issue that you need to be aware of is that switching power supplies that have voltage and current controls the current usually does not have very good current control below 200 milliamperes it drops rapidly not smoothly just be aware of this issue some switching power supplies that have both voltage and current controls are better than others
          • m1ch43lzm
            • Mar 2019
            • 1022
            • Peru
            There's also the "Dell/Alienware power meter box" from here https://www.thingiverse.com/thing:7031863
            The middle ID pin just passes through from the original AC adapter to the output cable, the volt-amp meter is wired to the input DC jack, and the output is a cable cut from a dead charger
            Lets you use regular Dell AC adapters, of course only for Dell laptops
            It relies mostly on the short circuit protection on the original Dell AC adapter, it's useful to measure power draw, not so when injecting voltage into a short circuit
            Instead of powering the laptop from the bench/lab SMPS, you power it from the original charger with that meter box inline, as gaming laptops can exceed 5A when booting in some cases
            For the USB-C powered laptops, get a 100W USB-C PD charger from a reputable brand and use an inline USB-C volt/amp meter, you have to check if the laptop negotiates 20V from the charger, or gets stuck at 5V/looping 5v-0v
            Ideally you don't want to push 20V through the USB-C connector, the laptop has to negotiate first
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • rabsonnjala
              LENOVO IDEAPAD 100 works only on bench power supply
              by rabsonnjala
              Hie I have a Lenovo laptop
              Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
              it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
              below are my readings
              with the original charger only
              JBATT1
              PIN1 0.22V
              PIN2 0.22V
              PIN3 0.45V
              PIN4 0.45V
              PIN5 O.43V
              PIN6 0V
              PIN7 GND
              PIN8...
              11-20-2021, 08:32 AM
            • Agent24
              Dick Smith Q-1760 linear power supply filter capacitor question
              by Agent24
              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
              It has at least one problem.
              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
              I have already ordered a replacement potentiometer, so that's not an issue.
              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
              All are CapXon...
              10-21-2025, 05:39 PM
            • dragon3x
              >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
              by dragon3x
              Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
              that is still quite new, as it worked OK for some months until it failed.
              At the time I was not into power supply electronics; it was put
              aside and a new power supply installed inside the computer. Also at the time
              power supplies were half the price of today's.
              On the PCB there are a D339 and 7500B chips.
              I have found that schematics with these 2 chips (see included file).
              Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
              Some measurements,...
              06-05-2024, 03:34 PM
