component identification
  • Shane711
    • 493
    Re: component identification
    The Bad Power board is putting out 12.77 VDC and the good Power Board is putting out 12.74 VDC. The voltage is there even when the main board is unplug for both boards.
    • Shane711
      • 493
      The bad Power Board has 12.77 VDC at the connector CNM803. With and without the main board plugged in. And the good Power Board has 12.74 VDC With and without the main board plugged in. Not sure what is wrong with this board.
      Not worth fixing I guess. Taking too much time and these boards are very cheap on eBay. I have an extra here so I am just going to install that one. I just want to understand what is wrong with the board. I guess if I don't figure it out now I may not the next time. I am thinking it may be an IC.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5076
        • New Zealand
        Originally posted by Shane711
        A friend of mine asked me to fix this TV. He said his wall receptacle has a short in it. I am not sure if that caused this or not but I do not think he opened the TV because he doesn't even know what a soldering iron is.
        That doesn't make sense, but non-technical people often use the term 'short' to mean anything.
        BUT, a loose connection at the wall socket could cause current spikes as the power supply cuts in and out, and that may well damage a PSU.
        -David VanHorn
        • Shane711
          • 493
          These Power Boards are on eBay from $9.00 to $15.00 so no point on putting a lot of time into fixing it unless I don't have nothing else better to do. So I will put in my pile of things to fix.
          • skynetronics
            • Mar 2016
            • 12
            • Chile
            Guys, i write from Chile. Gimme a hand here, please.
            I have a Samsung PSU BN44-00772A and a "technician" (i guess) tried previously to repair it.
            The PSU has a diode removed from it, that is located on position DP801CS. The fuse and MOSFET blown too, but that's on place.
            I just have the PSU on my hands, so i can't upload photo of the unit or the other boards.
            If someone has this PSU, i'll really appreciate if can write me here what part is that diode.
            Sorry for my bad english folks, hehe.
            Greetings from Chile.
            • R_J
              • 9607
              I can not find the original number for DP801CS, but the BN44-00707A uses a U5A6CD Ultra-Fast recovery Diode, Case: DPAK
              Most are rated at between 6~15 amps and minimum 600 Volts
              • skynetronics
                • Mar 2016
                • 12
                • Chile
                #27
                Thanks, matey.
                That reference is useful.
                If someone else have some clues about this, i'll very grateful.
                • skynetronics
                  • Mar 2016
                  • 12
                  • Chile
                  #28
                  I update this thread to inform in reference at post #25 that DP801CS was an ultra-fast diode U5A6CD just like R_J said.
                  Thanks, dude.
                  • R_J
                    • 9607
                    Glad to here its up and working again.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • AllElectronicsRepairs
                      Possibly Zener diode identification
                      by AllElectronicsRepairs
                      Hi Everyone. I have a shorted diode marked 15A 435. It's most likely a Zener since it was connected with the anode to the ground. I tried to find its reverse voltage value on the internet without success. Can anybody help?
                      02-09-2023, 07:54 PM
                    • nev1001
                      What zener diode might fix the sound on Maestro Mayhem gaming chair?
                      by nev1001
                      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                      I think an issue could be a zener diode (or capacitor) which has shorted out.
                      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                      04-17-2025, 05:09 PM
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
