Diode identificatiion.
  • Henriquez
    • Feb 2025
    • 6
    • Nederland
    Can somebody identify the diode D3 on the picture?
    After googling for weeks now, with my limited knowledge of diodes, trying to go just by the color coding (white-green), I still cannot find something that looks similar.
    It is on a VFD display and so far:
    - I have verified that it is broken, since it reads 0,058v both ways with multimeter in diode mode.
    - I also measured the D3 on a functioning VFD module and that one does read 0.488v one way.
    So, if anyone could identify the diode or enlighten me about what else I could be measuring (with a DMM) to find the correct replacement, I'd truly appreciate it.
    Many thanks in advance.
  • petehall347
    • Jan 2015
    • 4428
    have you removed it to test ?
    • Henriquez
      • Feb 2025
      • 6
      • Nederland
      Thanks for your reaction.
      No, I tested it in circuit; I didn't realize that that would make a difference, but I'll remove and measure it tomorrow.
      • Henriquez
        • Feb 2025
        • 6
        • Nederland
        I just removed the diode as advised and now it does indeed measure 0.550v correctly.🙂
        I also removed the capacitor that this diode is connected to, which was measuring "low capitamce/leaky" while in circuit, and now this one also is reading the right capitance outside the circuit, though with fairly high ESR.
        With no schematic of this module to be found and me only having basic experience with mainly audio circuitries, I'm a little at a loss. 😞
        • petehall347
          • Jan 2015
          • 4428
          try cleaning that mess on the board and any other messy bits .then look for anything that appears shorted
          • Henriquez
            • Feb 2025
            • 6
            • Nederland
            Will do, thanks again.
            • hobostove
              Corsair RM1000e - Help identify 5VSB Zener diode
              by hobostove
              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
              There's a 22ohm resistor that's melted and open, but it still has the bands.
              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
              It looks like the diode connects the source and drain of a TNY284...
              03-27-2025, 02:25 PM
            • jjne
              AUO M270QAN01 - identify diode?
              by jjne
              I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
              Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
              ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
              01-24-2024, 08:39 PM
            • jezzaaaa
              Identify replacement diode
              by jezzaaaa
              I'm trying to find a replacement diode for one that has gone short.
              I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
              I can't find the exact part number for sale. Similar...
              05-09-2023, 11:26 PM
            • gurj1979
              Ubiquitiu 24 port POE. Help Identify Diode 3pin)
              by gurj1979
              Hi again guys.
              Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
              I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
              Anyone help me identify the model of this Diode ?...
              08-23-2023, 08:39 AM
            • rddube
              Asus C423N motherboard - trying to identify diode
              by rddube
              Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
              Many thanks!
              Ray...
              06-24-2023, 08:08 PM
