Dummy load in place of 1000V AC CCFL bulbs
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys,
    Just wondering if anybody has any suggestions for a dummy load for those 1000V CCFL bulbs used in ~19/22 inch TVs.
    thanks,
    J
  • selldoor
    Slow Learner
    • 7870
    Re: Dummy load in place of 1000V AC CCFL bulbs
    I think there have been a few ideas using resistors to trick the system but
    as each set is different its difficult. There is also a way of tricking the
    error detection circuits but nothing concrete.
    Best plan is probably this:
    https://www.badcaps.net/forum/showth...er+testing+cfl
    It is in budms signature on any first post he makes in a thread.
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Hi Selldoor,
      I was thinking along the lines of what you are saying, i.e. using a high wattage resistor plugged in in place of the bulb... I think guitar amp repairers use this trick a lot... (instead of having the speaker as the load while they are testing it).
      I remember a trick to fool the error detection where I soldered an LED between the CCFL controller chip and ground. It worked on one particular set but it was messy...
      There seems to be a lot of kits available for testing laptop screens but not monitors/TVs.. Except those expensive bulb testers..
      I'll have a read through that other thread.. thanks,
      J
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        http://tangyind.blog.com/2011/10/04/...ection-method/ may be of use.
        http://tel-spb.ru/inv_za.html also might help if you want to bypass the IC protection. Use Google Translate if you can't read Russian.
        Might be better off with the budm's CFL trick though, as selldoor already mentioned.
        -David VanHorn
          • 31013
          you can buy a 12v invertor and a pair of coloured tubes for a few $ from pc customising places.
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • AJ847.63e
            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
            by AJ847.63e
            Hi Folks,
            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
            05-06-2025, 10:37 PM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            09-06-2024, 10:56 AM
            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
