How should I read this chip inductor?
  • Deong
    • Apr 2024
    • 13
    • 11-6, Nambusunhwan-ro 65-gil
    It is used on the laptop motherboard.
    One of the same two burned down.
    I looked it up by myself, but I can't read it after R22.​
  • vanminhscdt@gmail.com
    • Jul 2022
    • 74
    • Việt Nam
    The inductor information is only R22, the last 2 rows are the manufacturer's LOT code.
    What do you need to find?
    • Deong
      • Apr 2024
      • 13
      I understood the R22, but I didn't understand the code (LOT) below. So I just need to look at the R22?
        • Jul 2022
        • 74
        • Việt Nam
        R22 is its value, need to see schematic for detailed information. And LOT is this:
          • 31138
          find out why it burned before you replace it - you may have a shorted part overloading it.
          • Deong
            • Apr 2024
            • 13
            The water dropped and I had a problem with that R22, and after removing it, the problem disappeared. It was connected just before the bios chip past the superio, and voltage input to the bios chip was not possible.
            The board pattern is a little damaged, so I scraped it on both sides and gave it a very weak voltage, and it's booted.
            Thanks for your concern.​
            • Deong
              • Apr 2024
              • 13
              I had the same board, so I measured the details. Just curious. Thanks!
              • R_J
                • 9579
                This might be the part VCHW084T-R22MS5 check the dimensions
                • truclacicr
                  • Apr 2019
                  • 331
                  • australia
                  R22 = 0.22uH
                  • Deong
                    • Apr 2024
                    • 13
                    Thank you !
                    I bought the r22 resistance, checked and replaced the same after waveform inspection with an old oscilloscope, and it booted. Thanks a lot!
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                      by momaka
                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                      09-19-2021, 08:44 PM
