How should I read this chip inductor?
  • Deong
    • Apr 2024
    • 13
    • 11-6, Nambusunhwan-ro 65-gil
    It is used on the laptop motherboard.
    One of the same two burned down.
    I looked it up by myself, but I can't read it after R22.​
  • vanminhscdt@gmail.com
    • Jul 2022
    • 63
    • Việt Nam
    The inductor information is only R22, the last 2 rows are the manufacturer's LOT code.
    What do you need to find?
    • Deong
      • Apr 2024
      • 13
      I understood the R22, but I didn't understand the code (LOT) below. So I just need to look at the R22?
        • Jul 2022
        • 63
        • Việt Nam
        R22 is its value, need to see schematic for detailed information. And LOT is this:
          • 30977
          find out why it burned before you replace it - you may have a shorted part overloading it.
          • Deong
            • Apr 2024
            • 13
            The water dropped and I had a problem with that R22, and after removing it, the problem disappeared. It was connected just before the bios chip past the superio, and voltage input to the bios chip was not possible.
            The board pattern is a little damaged, so I scraped it on both sides and gave it a very weak voltage, and it's booted.
            Thanks for your concern.​
            • Deong
              • Apr 2024
              • 13
              I had the same board, so I measured the details. Just curious. Thanks!
              • R_J
                • Jun 2012
                • 9535
                This might be the part VCHW084T-R22MS5 check the dimensions
                • truclacicr
                  • Apr 2019
                  • 299
                  • australia
                  R22 = 0.22uH
                  • Deong
                    • Apr 2024
                    • 13
                    Thank you !
                    I bought the r22 resistance, checked and replaced the same after waveform inspection with an old oscilloscope, and it booted. Thanks a lot!
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                      by momaka
                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                      09-19-2021, 08:44 PM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
