72v to 12v 10A output is high 19.6v
This topic has been answered.
  • marce002
    • May 2018
    • 316
    • Argentine
    hello, this is from electric moto scooter... something happened and blown an onboard fuse in the converter box..replaced it and also replaced a bulged cap 100v 100uf ... now works but get 19v in the output instead of 12V...
    what else to check please!! this is the board:
    Marcelo J
  • Answer selected by marce002 at 11-11-2024, 07:54 PM.
    R_J
    • 9579
    It looks like the feedback voltage on pin2 is too low, check the components around the optocoupler and the opto itself, you can check the voltages on the opto as well, check the two pins on the primary side using pin5 of the KA3845, as ground, and check the two pins on the secondary side using the black wire as ground. post the optocouplers number as well
    Looking at the circuit, the vcc pin is also connected to one pin of the opto on the primary side, so one pin should be around 19v. the pin next to it that goes to pin2 of the ka3845 (via a couple components I can't see in the picture due to the wires) should have around 2.5v.
    You could also just check the voltage across the two pins of the opto, check across the two pins on the secondary side (led) and across the primary two pins (photodiode)
    • R_J
      • 9579
      You likely need a load on the output and it would drop down to 12v, Without a load the output cap can charge to the peak voltage of around 19vdc
      • marce002
        • May 2018
        • 316
        • Argentine
        that is the first i check... it still is 19.34v with lights on and all turned on... besides the audio center and BT device does not work due to overvolt... what else to try?
        note the 3 resistors 1kohm near the transformer seems to be quite hot to touch, but maybe normal
        Marcelo J
          • Jul 2011
          • 6057
          What is your battery voltage at the battery
          • R_J
            • 9579
            Post a clear picture of the back of the board so we can trace the circuit.
            • marce002
              • May 2018
              • 316
              • Argentine
              battery is 84v ... pictures:
              Marcelo J
              • R_J
                • 9579
                What is that solder blob on pin 5 of the ic?
                There is an optocoupler off the output as well as a glass diode, the diode may be a zener diode? There are a couple components under the output wires I can see. It may be that the opto is not providing feedback so the power supply can't see the output voltage and is running full output
                The three 1k resistors seem to be in parallel across the output.
                  • Jul 2011
                  • 6057
                  Is this an electric car or something else
                  • truclacicr
                    • Apr 2019
                    • 331
                    • australia
                    This appears to be the main controller (UC3845D):
                    https://www.mouser.com/datasheet/2/149/uc3844-309655.pdf (datasheet)
                    https://www.ti.com/lit/ds/symlink/uc3842.pdf (datasheet and application circuit)
                    AIUI, the VREF = 5V and VFB = 2.5V when the IC is regulating properly. If these voltages are correct, then I would be looking at the resistive divider that is connected to the output voltage that is being sensed.
                    • R_J
                      • 9579
                      Yes, it is an ICF KA3845D, the ic is working, but seems to be lacking proper feedback
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        The values measured are (no load )
                        Marcelo J
                        • R_J
                          • 9579
                          You need to use pin 5 (ground) of the ic for reference when checking the ic voltages. what is with that solder blob I asked about in post #7
                          The primary and secondary grounds are isolated by VD1 (can't see its number) likely a dual fast recovery diode
                            • Jul 2011
                            • 6057
                            Here is the data sheet for this KA3842B
                            https://www.mouser.com/datasheet/2/1...iRhhm50qRK_C0_
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              sorry, the blob is ok, just me replacing a zener but was not shorted and the other blob on + is a wire + used with my power supply to test also ok.
                              i will recheck and report back Volts, because ic gnd was not my reference, used wire conecror gnd, my fault.thks
                              Marcelo J
                              • marce002
                                • May 2018
                                • 316
                                • Argentine
                                hi the values from GND pin 5 with out load (blue) and with lights (green) on are:... and just in case the diode im VD1 and the other one on left V1 are: VD1= MBR20100CT and V1= HY1710
                                Marcelo J
                                • R_J
                                  • 9579
                                  • marce002
                                    • May 2018
                                    • 316
                                    • Argentine
                                    Thanks a lot T J!! it was a 320 ohm resistor close to the opto, whose value was wrong and turned out to be burned in the hidden bottom side. tks now output is 12.8V the end
                                    Marcelo J
                                    • FrancescoV
                                      Onkyo HT-R390 no sound output, video output ok
                                      by FrancescoV
                                      Good morning everyone,
                                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                      The firmware reported is the following:
                                      M:1.00/11107BLP
                                      D:?.??/????????
                                      O:1.00/11107AL
                                      The DSP firmware given the question marks seems corrupt.
                                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                      05-11-2025, 02:59 AM
                                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                      by sam_sam_sam
                                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                      I bought this from an eBay seller but unfortunately they only had one
                                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                      I bought three of from them to also make battery packs with this output power limit in mind
                                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                      04-23-2025, 05:50 AM
                                    • CoppellTVRepair
                                      Troubleshooting PFC with SPC1012T not raising output
                                      by CoppellTVRepair
                                      It has been a long while since I posted here to ask anything....hope you can help.
                                      I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                      I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                      03-09-2025, 10:38 PM
                                    • mecha1166
                                      Copper corrosion? Yamaha HS8S Audio 1 output only
                                      by mecha1166
                                      OAUD Yamaha HS8S Audio one output only.
                                      I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                                      08-04-2023, 02:55 PM
                                      MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                                      The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                                      Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                                      10-23-2024, 03:23 AM
