Hi everyone, I need to read and reprogram the d78f0034acw microcontroller. is this possible with RT809H? Thank you
d78f0034acw flash
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by spmetroilHello,
I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
I have a CH341A programmer and I already attempted the following steps:- Identified the correct chip (W25Q128, 3.3V SPI flash).
- Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
- Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
08-19-2025, 09:23 AM -
by abajorHello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
I think my best shot is to figure out a way to read the internal flash memory outside... -
by IhandyrepairHI guys
I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
here is the issue
I have Sony and android logo. but then 4 led red flash lights front of the tv
I have 3.3v ref. 12v reg then T con 12v when I press the power on button
but then I get black screen and 4 red flash light at the front LED
but I get 3 led flash on the LED driver board.
I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
so I tried... - Loading...
