d78f0034acw flash
  • ibrax
    • Jan 2021
    • 9
    • italy
    d78f0034acw flash
    Hi everyone, I need to read and reprogram the d78f0034acw microcontroller. is this possible with RT809H? Thank you
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • abajor
    Canon VIXIA HF S10 A read data from inernal flash memory.
    by abajor
    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
    I think my best shot is to figure out a way to read the internal flash memory outside...
    07-20-2024, 12:04 AM
  • Ihandyrepair
    4 red flash led 65X950G boot Sony and android logo but then black
    by Ihandyrepair
    HI guys
    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
    here is the issue
    I have Sony and android logo. but then 4 led red flash lights front of the tv
    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
    but then I get black screen and 4 red flash light at the front LED
    but I get 3 led flash on the LED driver board.
    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
    so I tried...
    07-11-2024, 01:45 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
