E-Scooter battery not charging.
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Dear forum,
    I have succesfully repaired a Ninebot Kickscooter E2 control unit, which had a burned MOSFET on it. (Thank you sam_sam_sam )
    Now after replacing the faulty component, the scooter turns on and working as should but I noticed, that when I plug in the charger, the charging animation shows on the display, but it actually won't charge the battery.
    After dissassmbling the battery, I found out that I can charge the battery trough the discharge plug (the big yellow one) If I connect it to my PSU. But I cannot charge it when I connect the PSU to the charging wires.
    What could cause this issue?
    • 30991
    it could be protection,
    check the voltage of each cell-bank - they should match or be very close.
    also it probably wont charge if the cell voltage is too low.
    unfortunatly "too low" seems to be a bit vague - some stuff thinks 3.5v and some will charge at 2.5 or even 2v
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      Should I try first charge it to 100% with my PSU?
        • 30991
        not till you check the cell voltages
        • unimatrix93
          • Oct 2021
          • 343
          • Magyarország
          Allright, will check each bank tomorrow and report back. Thank you!
          • unimatrix93
            • Oct 2021
            • 343
            • Magyarország
            So the battery charge is at 16% now according to the display.
            I disassembled the battery pack, the output plug has 15V on it.
            Here is the top and bottom side of the battery pack:
ID:	3496784 Click image for larger version
            How should I measure these banks to get the correct values?
              • 30991
              you have access to all the battery tabs so just meter the 6 groups of 4 cells and see if they match or are close to each other
              now lets talk numbers.
              it has 6 groups so 6x 4.2v is 25.2v fully charged.
              15v divided by 6 meaans you have 2.5v per cell right now - witch is potentially below the safety threshold of the protection board.
              if they all match then forcing them upto 18-20v will probably get it working on the original charger again.
                • Jul 2011
                • 6037
                Be careful jumping the voltage up to high if your current is more than one amp going to the battery some BMS boards do not like this situation and will either turn on and go right back off or just refuse to charge now you can bypass the BMS board but if you do this only charge it up so that each has reached 3.00 and no higher than one amp and by all means keep an eye on the temperature of the battery cells if they start getting warm stop bypassing the BMS board and only use the battery charger that is for the battery pack
                • unimatrix93
                  • Oct 2021
                  • 343
                  • Magyarország
                  The battery charger rated output amper is 1.5A. That measn I can safely charge the battery pack with 1.5A trough the discharge plugs. no? Or should I use 1A just to be sure.
                  The battery packs current voltage is 14V.
                  I measured the tabs in the following order:
                  B+ - B5 = 3.5V
                  B4 - B3 = 3.5V
                  B2 - B1 = 3.4V
                  B- - B1 = 0.0V
                  Based on this I assume B1 is dead, which causes the pack to become inbalanced so the BMS disables charging.
                  What do you guys think?
                  • kevingill
                    • Jun 2013
                    • 152
                    • England
                    That would only make 10.4v, so you must have missed out a couple of legs of cells.
                    You've only shown 4.
                    Report B- to B1, B1 to B2, B2 to B3, B3 to B4, B4 to B5, B5 to B+
                    • unimatrix93
                      • Oct 2021
                      • 343
                      • Magyarország
                      You are right!
                      B- to B1 = 0v
                      B1 to B2 = 3.4v
                      B2 to B3 = 0.4v
                      B3 to B4 = 3.5v
                      B4 to B5 = 3.3v
                      B5 to B+= 3.5v
                        • Jul 2011
                        • 6037
                        Originally posted by unimatrix93
                        You are right!
                        B- to B1 = 0v
                        B1 to B2 = 3.4v
                        B2 to B3 = 0.4v
                        B3 to B4 = 3.5v
                        B4 to B5 = 3.3v
                        B5 to B+= 3.5v
                        Do not attempt to recharge this battery pack until you resolve the issue with B- to B1 and B2 to B3
                        It is very possible that the battery cells have an issue with self discharging sin drum and if this is the case it would be better just to replace all battery cells with brand name new ones or barley used ones
                        Here is how you can determine if you have the self discharge sin drum let the battery pack sit for 30 days and see if the voltage between the different battery cell rails right now you have a difference of 0.3 volts if it has discharge sin drum this difference will get bigger than what you see now
                        It is not a very good idea to just replace the battery that have no voltage or very little voltage with new ones
                        Now with that said you can use battery cells that are used BUT make sure that you test each battery cell for milliamperes hour and try to match them as close as possible you can for best results the brand and series is also important but milliamperes hours of each battery cell is more important than not matching them as close as possible
                        For best results if I were fixing this battery pack I would replace all the battery cells with brand new or barley used battery cells that are brand name battery cells
                        For best results you should test each battery cell to know what the actual milliamperes hours are because if they are more than 50 milliamperes some BMS protection boards do not charge and discharge battery cells unevenly unless they have a balancing function incorporated in the BMS so this is where you have to do the balancing the battery cells as close as possible for best results
                        Even if the BMS protection board has a balancing function it still important to balance the battery cells as close as possible for the best possible performance so the balancing function does not have to work harder to get the battery cells balanced
                        • unimatrix93
                          • Oct 2021
                          • 343
                          • Magyarország
                          I see,
                          I just want to restore the recharge function of the battery. I don't mind if it's not a 100% fix, since I already spent so much time and money on it.
                          So I should proceed and replace the batteries between B- and B1 and B2 and B3.
                          The orignial batteries are GP brand inr18650/26l 2550mAh. I only have significantly smaller cells like 1850mAh sadly.
                          I checked around and I found some Tenpower INR18650-26ME 2600mAh cells from a reputable webshop.
                          can I use these to replace the dead cells between B- - B1/B2-B3?
                            • Jul 2011
                            • 6037
                            It would better than not doing anything however just be aware of the fact that your running time will suffer somewhat because of doing it this way
                            If you are going to do it this way just have each group of battery cells basically have the same amount of voltage before you put the battery pack on the battery charger
                              • 30991
                              it's a high current device,
                              look the batteries up here and see how much current they can dump into the load.
                              https://secondlifestorage.com/index..../cell-database
                              • unimatrix93
                                • Oct 2021
                                • 343
                                • Magyarország
                                I couldn't find the original cells in the database but I think I found them via google:
                                GP INR18650/26L Low cost battery cell - 18650, 21700, 26650, LiIon and LiFe
                                • unimatrix93
                                  • Oct 2021
                                  • 343
                                  • Magyarország
                                  Understood, and is it safe to disconnect the BMS from the cells? I mean it shouldn't lock itself by doing this right?
                                  • unimatrix93
                                    • Oct 2021
                                    • 343
                                    • Magyarország
                                    Also, I think I must remove all the metal tabs from the BMS, since I cannot open up the plastic case. I removed every screw yet the two part wont seprate. I guess The tabs are holding it together.
                                      • Jul 2011
                                      • 6037
                                      You more than likely will have to remove the battery tabbing to get to the battery cells that you need to replace anyway so that why I mention about just replacing all of them that are more or matched hopefully
                                        • Jul 2011
                                        • 6037
                                        Thanks for sharing this information saves me a lot of time looking them up
                                        • dqtech
                                          acer travelmate p214 status "charging" but battery percentage not increasing...0mW charge rate
                                          by dqtech
                                          early problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
                                          i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
                                          schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile...
                                          05-04-2025, 04:42 AM
                                        • Shinju
                                          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                          by Shinju
                                          Hey All!
                                          Long time forum member here with a problematic laptop issue!
                                          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                          The laptop would not power on with the new battery installed without the power supply being plugged in.
                                          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                          10-20-2021, 04:58 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
