How to modify the circuit to increase the range?
  • sudheerelktronics
    • May 2014
    • India
    Hi!
    I have recently seen a post: FM Transmitter.
    I felt that this concept is very interesting and the circuit also seems to be easy to implement. I am planning to do this project. But, here it is mentioned that it can work up to 2km. only. i.e. It's range is 2km.
    Can anybody suggest me the required modifications to be done in the circuit and also the values to be changed to increase the range up to 15 km?
    And also, Is it possible to use this circuit in forests in real life?
    Kindly clarify my doubts.
    • 31283
    Re: How to modify the circuit to increase the range?
    forget that design.
    if you search a bit, there are some very powerfull transmitter diagrams about.
    http://xtronic.org/category/circuit/transmitter/
    • Elysarian
      • Mar 2013
      • 200
      One thing to remember with radio transmitters is the inverse square law.
      You're looking to increase the range by a factor of 7.5 so the output power (for the same received signal strength) would need to be increased by a factor of 56.25...
      the BC109 can dissipate at most 300mW - so (assuming nothing else changes and there are no additional losses) your output transistor would need to be able to dissipate around 17W.
      I built something similar to this as a college project many years ago (we also built an AM receiver)
        master hoarder
        • May 2008
        • 12175
        Another thing is the antenna - bigger is better and the higher you mount it, the better.
        Also, I suggest staying away from cheap PLL VCOs such as the ones found in cheap car FM modulators - they tend to "broadcast" (if you can call it that) on multiple frequencies at a time. Their output is kind of "dirty" too.
        A simple FM circuit like the one you found is quite simple (I mean that in a good way) and if soldered on a vector board, you can actually get pretty clean and stable output. I built something similar on a breadboard, and it worked okay for the most part. A common problem you may encounter with passive resonators, however, is drift. It probably will take some time for the circuit to settle on a frequency as it "warms up". Once warmed up, it will be stable for the most part. Might need very occasional tune-ups. I was actually planning on building that 2KM FM transmitter too, someday. Just never seem to get to it. I definitely want to try it with a home-made varicap, though. The small ones available from the store tend to be too sensitive (either that, or you can tune your circuit to a certain frequency and then design it so the varicap just "fine-tunes" the frequency).
        Lastly, I saw one circuit on that xtronic website above that suggested using 741 op-amp for the audio amplification - that's a big NO-NO in my book. 741 is a terrible for audio amplification. Avoid!
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
          RCA WHP141 wireless headphones wired up
          by momaka
          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
          02-22-2023, 06:28 PM
        • Tarot Superstars
          Short Circuit tester
          by Tarot Superstars
          Hello.
          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
          Link
          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
          https://www.youtube.com/watch?v=0eixDdCpiO4
          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
          09-25-2023, 09:11 AM
        • Alimash
          op amp circuit function?
          by Alimash
          I am repairing a ups which doesn't turn on ,it has the following ICs:
          SG3525 used to drive inverter mosfets.
          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
          A LM358 and TL074 for control mechanism and of course the uController.
          The SG3525 is shutting down every time the ups is turned on.
          I want your help to know the function of LM358 and TL074 in the system.
          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
          07-31-2025, 07:45 AM
        • M1NEBLANK SHOW
          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
          by M1NEBLANK SHOW
          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
          Schematic and Boardview here
          04-04-2025, 03:57 PM
