362142 pwm ic chip.............what it might be? Vd
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    I am trying to fix this 24Vcc swich power supply that has no output voltage. The problem might be in the PWM controller, however, I haven't been able to find the datasheet for this PWM IC tiny controller. Any idea?
    (I am attaching some pictures for a better understanding of my troubleshooting)
    Tracking the PCB:
    GND pin 1
    Feedback pin 2
    RI pin 3 (100k between pin and hot ground).
    Sense pin 4 (470ohm to source)
    Vdd is pin 5
    Gate pin 6
    Maybe it's just an OB2262/ OB2263MP (or could be replaced by these ones). Pinout seems the same.
    When I am plugin it the PCB (as it's like in the picture), Vdd starts increasing and get's stable at about 79V!!!! Vdd cap hasn't exploded yet, but it's rated 50V. This seems so much for a PWM controller..............what's might wrong there?
    Between R1 and R2 there are 3M ohm (in the middle point 1.5Mohm), then it goes R3 with 200k...........at this point there is Vdd entrance...........also connected to the cap, diode and then hot earth..........that high voltage on Vdd is because IC is not installed?
    Also.......all this bunch of resistors are connected in the AC entrance............before the rectifier. Not as in the OB2262 schematics.
    Lost in translation.......trying to understand :-)
    Regards,
    Francesc.
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Yes!! with the IC installed the voltage decreases between 13-16 V...................but fluctuates!!
    Fluctuates with mosfet installed or without...........doesn't matter. Vdd cap is in good conditions (10uF 50V and low ESR).
    What could be the reason of fluctuation? Faulty IC?
    I will check in the meantime the optocoupler............not sure if it can be "shorted" to just check the primary side.
    Regards,
    Francesc.
    • truclacicr
      • Apr 2019
      • 331
      • australia
      The typical fault with these supplies is that the capacitor on Vdd dries out and goes high ESR.
      When the IC is in start mode, the Vdd capacitor is charged from the main rectifier by the resistor, typically 100K or more. When the voltage reaches a certain threshold, the IC switches to run mode and pulses the MOSFET. The capacitor's charge is then replenished via the auxiliary secondary winding of the transformer. If the supply doesn't come up, such as when there is a shorted output, then the capacitor's charge is depleted until it falls below the start threshold. The IC then reverts to start mode and the cycle repeats. This results in hiccuping.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8284
        It fluctuates on Vcc because it's trying to work, but can't. This does not automatically indicate the PWM is bad. As already mentioned in post #3 usually what goes bad is either the capacitor or the starter resistor is bad (higher ohms than it should be). I had a bad case of that starter resistor going bad. It measured good when cold, but after 20seconds the PWM stopped because the resistance was then too high not giving enough Vcc for the PWM.
        • Francesc V.
          Tempus fugit
          • Nov 2022
          • 231
          • Catalonia
          I will have a look to your comments.......thanks!. Let's see who gets the BINGO.
          In this case, the output is flat always. No variation of any voltage at all. I am saying this because sometimes when something is shorted on the secondary, you see some fluctuation.........not sure if it's a fact or I am completely wrong.
          Will check all SMD components starting in the primary section. As I said, Vdd cap is in excellent conditions so far. I will pay attention on the resistors.
          Regards,
          Francesc.
          • lotas
            • Jan 2016
            • 4706
            • Russia
            This is OB2362AMP
            • harp
              • Jun 2022
              • 615
              • Planet Earth
              ob2362a
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                I''ve ordered the chip.........let's wait for the final outcome.
                I haven't found any damage resistor (startup resistor is fine at 20k). Also Vcc capacitor looks good in capacitance and ESR. Furthermore I don't see any gate signal in the oscilloscope.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8284
                  Also could be that the chip is in a protection mode somehow.
                  • Sam Scarbo
                    • Oct 2023
                    • 38
                    Sometime ago, i tried to troubleshoot a 12V wi-fi router adapter that has gone bad. After a few hours of experiments and some exciting firework/sparks, when I found the OB2263 family SMD chip (with "61050" marking on it) was dead, I gave up.
                    You said you have ordered your OB2362a chip. You should also check the MOSFET is not damaged.
                    Good luck!
                    • Francesc V.
                      Tempus fugit
                      • Nov 2022
                      • 231
                      • Catalonia
                      I give up on this one........xDD
                      Chip changed.......but same result. Vdd chip is fluctuating / restarting
                      Starting up resistors changed,
                      No voltage detected in pin 3
                      Voltage output sligthly increases within minutes from 0 to a 1.7V (nothing seems shorted on the secondary section).
                      I've changed TL431, checked resistors there.........and also the optocoupler.
                      Too much time invested on a shitty SMPS. xDDD
                      • cheeky2
                        Tivoli Music System+ no backlight on display resolved
                        by cheeky2
                        Just had a Tivoli Music System+ without any led backlight display it turned out to be a variable 100k pot had gone open circuit on the variable leg on the pot!
                        I haven't seen any information out there on the internet regarding these units so thought it would help others in there search for resolving it!
                        The hot glue over time I guess which was all over it before I pulled it out had caused the issue with time.
                        The unit uses 3V leds behind the lcd display to illuminate it together with a photoelectric sensor to adjust the light output for the light intensity of the leds....
                        04-30-2022, 07:15 AM
                      • Maxpower3
                        Lenovo Thinkpad L15 Gen 3 Power Btn not working Wistron 223030-1
                        by Maxpower3
                        Hello
                        Works perfectly except the power button.
                        You have to start it with Cmos removal.
                        No réaction from the button.
                        The lights are présent.
                        3V and Gnd are présent on button
                        I made a request for the diagram here but it is not available.
                        MB Wistron 223030-1
                        Ref LG4 LT5 ADL RT UMA MB
                        https://www.badcaps.net/forum/troubl...-adl-rt-uma-mb
                        after...
                        01-17-2025, 06:40 AM
                      • evilkitty
                        Flux causing high resistance short?
                        by evilkitty
                        Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                        Temp is on the left humidity is on the right
                        i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                        The pin out looking down from the top is (note this is common cathode)...
                        07-17-2024, 09:38 AM
                      • fredyjbi
                        please help friends thinkpad T490 NM-B901 rev 1.0 dead no power usb type C 20v 0amp thank you
                        by fredyjbi
                        please help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
                        I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
                        PF0002 20v
                        PQ0005
                        pin 5 20v
                        pin 1.2.3 19.8v
                        pin 4 19.8
                        resistance
                        source & drain 2,4 m
                        source & gate 100k
                        PQ0006
                        pin 1.2.3 19.8v
                        pin 4 19.8v...
                        04-20-2024, 11:40 AM
                      • spleenharvester
                        Ugreen HDMI splitter missing a pulldown resistor
                        by spleenharvester
                        Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
                        I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
                        (Not that this is worth the hassle for an...
                        Today, 11:23 AM
