Using small current to activate transistor - will any transistor work?
  • JBL
    • May 2012
    • 5
    Hi.
    Well I was not sure exactly how to name the thread. But here Goes.
    I will try to keep this simple.
    Problem and Application :
    I have a Reciever Module and Sender Module in one of my projects.
    One wire from the Sender sends a very small +12v constant current to the reciever to trigger it to perform a function. I had to replace the reciever unit with a new one, but now does not take a +12v current on that same wire, it works on earth trigger, so it will not do anything if that +12v current is fed to it.
    Proposed Solution :
    So I was thinking, OK? Use that 12v signal to trigger a relay and let the relay switch a earth tot he reciever unit. Does not work as the 12v current is not strong enough to trigger a relay coil, power a bulb or anything like that, it's 12v but can hardly give any current.
    So I want to use that 12v signal to trigger a transistor, then use the transistor to feed power to activate a relay, and the relay will then switch an earth to my new receiver unit that requires earth instead of the old one that required 12v
    My Question is
    1. Can Any transistor work, or is there a certain current required to switch a transistor? I done it in the past on a previous identical project but forgot what transistor I used.
    2. Does a relay exist that I can buy with a built in transistor, so the relay can be triggered by very weak currents?, this way it will be much neater looking. I buy most of my stuff from RS Components which I have access to here in Australia where I currently live.
    3. Can I simply just use a transistor triggered by the weak +12v signal to switch earth to my receiver unit, without need to have a relay?
    • 31283
    Re: Using small current to activate transistor - will any transistor work?
    a transistor and resistor or a cmos invertor like a 4069
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Have a look at this:
      http://www.rason.org/Projects/transwit/transwit.htm
        So the new receiver uses active low for triggering, which mean it has pull up resistor at the input so you need to pull it down toward circuit ground, then you can use FIGURE 2 of the link that Steve provided, the Collector will be connected to the control port of you new receiver. R1 value will have to be adjusted depends on the pull-up resistor value in the receiver is. Also what is the distance of the control wire will be? if it is really long, the transistor may pick up noise and causes false triggering if it used in the noisy electrical environment.
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
          I tested the battery cells there are installed right now and they are testing good with no issues that I...
          02-04-2025, 08:08 PM
        • InsertCoin
          Relay Satronic MMI 810.1 bad diode & Transistor
          by InsertCoin
          Hello and happy new year ,
          my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
          There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
          The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
          I have made a diagram of the PCB and some measurements along some...
          01-16-2024, 05:47 AM
        • CuriousJohn
          Burco boiler power problem
          by CuriousJohn
          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
          12-22-2024, 10:25 AM
          Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
          The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
          All AP21X2SG-13 AP21X2MPG-13 devices are available...
          10-23-2024, 03:33 AM
