ULN2003 IC replacement
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello, on a step motor driver board,
    I have found damaged ULN2003 manufactured by ST as package SOP 16 (narrow). Now I have possibility to order get delivered very fast the following mark: ULN2003AFWG,
    I'm not really sure if this is equivalent IC.
    On the original I can (hardly) read the following data: G001284, and on this replacement IC there is also this: 024826
    So, are these two ICs equivalent or not? First one is made by ST and second one by Toshiba. Based on the available manuals and schematics it should be 100% match.
    What I need to pay attention to?
    Thank you!
  • mon2
    • 14691
    Any part with ULN2003 and the same physical footprint will work. The other markings are datecode, etc. and are no-care markings.
    You can also review the offering by Texas Instruments. Stick to one of these brand names as opposed to an offshore one from Asia.
    ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet (Rev. S) (ti.com)
      • 31264
      make sure it wasnt blown by a stuck stepper motor
      • Askic
        • Sep 2018
        • 187
        • BIH
        Thank you all for the replies. ULN2003 is replaced, everything works without problems.
        • issam19dz
          B450 AORUS M Looking for Equivalent Replacement for MOSFET EMF30N02J?
          by issam19dz
          I'm hoping to get some help finding a suitable replacement for the MOSFET EMF30N02J. I'm currently using this component in B450 AORUS M motherboard
          Any information or advice would be greatly appreciated!
          Thanks, [Issam Seb]
          05-01-2024, 04:26 AM
        • DXseekerMO
          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
          by DXseekerMO
          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
          If anyone has a link to where I can buy what I need that would be even better.
          These are the caps that have burst:
          Board location: C8BV, C26BV, C43BV
          Brand: United Chemi Con
          Series: KZG
          Size: 10mm dia X 25mm height
          Impedance: (ohms max/20c, 100kHz) .012
          Ripple: 2800...
          02-04-2022, 04:48 PM
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
        • sbt123
          charnwood w821 mini wood lathe motor problem
          by sbt123
          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
          10-27-2024, 03:43 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
