    • Jul 2011
    • 6112
    • Soldering Junkie
    This switching power supply that I replaced two smaller separate switching power with one much bigger switching power supply is the best thing I could have done to the soldering/desoldering station I am glad I found this switching power even though it is a Chinese brand switching power supply
      • Jul 2011
      • 6112
      • Soldering Junkie
      I decided to buy another ZD-987 desoldering/soldering station I have decided to sell one my ZD-917 desoldering/soldering station I will be posting it on eBay soon I will post when the item is available
      I decided not to move controller around to make it have the sleep function feature because this idea could become a nightmare
      I have changed controller boards on these units before and sometimes everything goes good and sometimes it goes wrong
      One more reason for not doing it was because I do not have a desoldering gun controller that has the sleep feature for the desoldering gun and the soldering iron controller are not programmed exactly the same way in that desoldering controller has slower temperatures response time the soldering iron does and would way over shoot the set point or would cycle way often so this is my concern about doing
      The reason I know this when there was an eBay seller that sold these replacement controllers you had to make sure that you bought the right version for the model number you have and the seller had this in the description for items for sale
        • Jul 2011
        • 6112
        • Soldering Junkie
        Update I was thinking about getting another 18 volt @ 20 amp output capacity switching power supply but the cost of them have gone up by $30.00 from a year ago I might take a while to make the decision weather or not to buy another one or not
        Very disappointed about this turn of events with these switching power supplies going up in price by this much in this short time frame
        They are decently made I have been using it for almost a year now and it works like a charm on my soldering desoldering machine and works so much better than the original switching power supply that was in it what is really nice and most importantly thing in the cooling fan and it being temperature controlled when the heaters turn on the fan speeds up and when the heaters go offline the fan slows back down again
        And most important thing is that the switching power supply can be on for hours and just be barely warm to the touch yeah I know this switching power supply is probably over kill for what it is powering but so much better in the long run
          • 32067
          on this subject,
          i have still not seen a single original psu failure in europe,
          i think it's the input voltage, 230v is good, but 110 has double the duty cycle so it stresses the semiconductors more.
            • Jul 2011
            • 6112
            • Soldering Junkie
            Originally posted by stj
            on this subject,
            You could be right about that but there is no easy solution for this other than using an external switching power supply at for me because I just got tired of repairing them and not really getting any where but I like I mentioned earlier in my comment above that now these switching power supplies are now $71.00 not as affordable like they were when I first found them and bought a couple of them I still have one of them to modify but I want to fix another device that has issues as well but I think I might hold off on doing it for awhile
              • 32067
              you should wire some 240v outlets in your workshop.
              they would be handy for all sorts of psu testing
              btw, china is 240v so getting stuff like rcd's and breakers is easy
                • Jul 2011
                • 6112
                • Soldering Junkie
                #27
                But you have to buy the 240 versions of devices for this to work because there are two versions of the soldering desoldering stations for the switching power supplies that I am referring to there is a switch to change from 120 to 240 volts
                  • 32067
                  i thought the soldering stations were universal voltage?
                    • Jul 2011
                    • 6112
                    • Soldering Junkie
                    #29
                    No you have to order the voltage version that you want or need there is no selector switch on this device
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5401
                      • New Zealand
                      • Electronics and computer repair
                      #30
                      Can't you upgrade the silicon to handle the 110v requirements better? That could be an interesting project... maybe a FET with lower Rds(on) and higher current rated rectifiers, etc?
                      -David VanHorn
                        • Jul 2011
                        • 6112
                        • Soldering Junkie
                        #31
                        The problem is two fold one is that the switching power supply transformer is not big enough for the current and second if that does not fail then the switching power supply regulator fails so like I said it is two fold
                          03-31-2024, 02:12 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          After all of...
                          07-13-2024, 08:14 PM
                          DVR camera recorder switching power supply capacitor failure really
                          These cheap non brand capacitors at it again
                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                          Well at least I have the cameras back on line I to try the...
                          01-22-2022, 06:28 PM
                          DVR recorder Switching power supply Failure
                          When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                          Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                          This...
                          05-27-2023, 03:03 AM
