Fluke 8808A not measure
  • eduaqa
    • Jun 2022
    • 16
    • US
    I bought this multimeter as part, and I'm trying to fix
    Initially when powering on, it was beeping, beeping and display was come on and off fast
    Doing a initial investigation I notice that the 7805 marked was warming ... I removed it and test the rail that it supply voltage and was short circuited
    I discovered to IC (latches) marked on the picture in short ... I replace the 2 IC and the rail now is having around 24ohms resistance, which still seems having some type of short circuit, because is cause a consumption of 370mAH, what seems too much, because when compared with the others rail which read very high resistance
    When I turn it on now, the display works, the push button on the front change as should, however none of the measures works
    I noticed that the 7805 is warming, as it should because it's providing 370mAH, also I notice that doesn't matter what function I choose I don't hear relays "clicking" and relays are also warming ... also measuring the voltage on the relays S and R coil that have around 4V, on both ... seems strange, I understood that should not have voltage on both at the same time, and maybe even not continuous
    Any help is welcome​
    • 31256
    a number of the 8pin chips look a bit strange in the picture
    • eduaqa
      • Jun 2022
      • 16
      • US
      sorry, what you mean? the quantity of 8pin chips? or those 2 that were replaced (16 pins)? Those that were replace are onsemi HC573A, exactly as was before, and just in case ... I tested pin by pin on those replaced to detect maybe jump solder between pins or not soldered pin and they are all good (not short between pins, no desoldered pin)
        • 31256
        i mean in the picture atleast 2 8pin chips look like the top is discoloured or damaged.
        • eduaqa
          • Jun 2022
          • 16
          • US
          Understood … those 2 (16 pins)cycled on the picture are new from DigiKey , the 2 that was there before was short circuited (0 ohms between gnd and vcc)
          on that situation it was not even turn on because of the short circuit on the rail and the rail was measuring 0ohms
          after I removed the 2 old one the rail become around 24 ohms , and here is my problem it’s still too low , should measure near open link
          so something more on the rail is still almost shorting the rail
          After soldering those new rail keep reading around 24omhs , so the 2 new should not be the ones causing that low measure
          im thinking that I will need desolder all components in that rail until the short goes, but try to avoid because will be a very hard work
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            A 24 Ohm short sound like shorted MLCC to me but could be something else as well.. Inject rated voltage for that rail using a bench power supply and crank it to one amp. Use 99% IPA and put some on the SMD's. If a cap is shorted it will get hot and evaporate the alcohol quickly. Saves you from fiddling around taken unnecessary parts off.
            • eduaqa
              • Jun 2022
              • 16
              • US
              I used that method to detect the 2 ICs i discovered in short (in the first round when rail was 0ohms) ... those 2 in the first picture (see the green wires connected to the 7805)
              I have a fluke thermal camera so I used it to detect what was warming
              But now the only thing warming was the relays after a few minutes,
              So I focused on that ... note on the new picture i desoldered 3 of the 5 relays ... after that the rail went to 140ohms (what is still high, should be Open Link)
              Now look the pictures ... relays a connected direct to the 5V rail and if I'm understand correct, that 3 pin device marked as 2A and a E or 3 on side is a NCHANNEL MOSFET and D is connect to the 0V rail ... when a tested it, between the D and S its shorted (conducting) ... i thought that maybe some residual voltage on the G was putting it on conducting state, but even if I short G and D, it still conducting between D and S
              Am I assuming correct that those device are NCHANNEL MOSFET? and should not conduct when I short D and G?
              I still have other 2 relays to desolder ... it seems that 20ohms was the coils from relays as all NCHANNEL MOSFET are conducting they are "clamping" the 0V to the coils.
                • 31256
                does the base have a resistor inline?
                my databook says 2A is a PNP 200mW transistor.
                FMMT3906
                • redwire
                  • Dec 2010
                  • 3912
                  The MCU might have outputs stuck high and turning on all relays - but no. Low power Ohms should not read anything then until the transistors get turned on. So it doesn't make sense unless all the relay driving transistors have shorted.
                  DS2E-SL2-5VDC-C-H245 latching relay has two coils 69.4Ω each. I think two transistor high-side to drive them SET/RESET.
                  • eduaqa
                    • Jun 2022
                    • 16
                    • US
                    GreatSage is right, that was a PNP transistor, and was shorting the C and E ... what put energy on the coils, and i didn't read this before, so first i though was N Channel, as I replace had the same problem (N Channel act as a diode and keep coils energized)
                    below i'm posting all step that could help somebody if need:
                    #1 meter was turning on, but all reading was showing OL in all functions
                    #2 I open it and I detected that transformer was just generating like 4-5v where it should be generating around 10V
                    #3 Disconnected the transformer from the board and than it was doing 10.5v, so some short circuit was in somewhere
                    #4 I detect that one of the 7805 was warming.
                    #5 I removed it and then the transformer starting generating then 10V as supposed.
                    #6 Testing the ground and +5v out on the board (with the 7805 removed), it showed 0ohms, so really a short after 7805
                    #7 here one mistake ... I looked around the 7805 and saw a few components around, so i decide to remove them ... mistake,, the board is multilayer (obvious), but i didn't noticed that on in a first look ... so after removing the components still showing 0ohms
                    #8 so then I discovered that there was a lot of components, so removing then was not an option
                    #9 so, with the 7805 removed, used an external power supply and injected 5v on that rail, looking for heating and was easy, those 2 chips I marked initially was heating (the picture is after replacing, not sure why seems discolored), removing them remove the 0ohms reading.t
                    #10 however, that reading was still 22ohms, what seemed to be low ...
                    #11 easy, use the same process with the power supply... not that easy ... this time no obvious heating and the AMP usage on the power supply was not too high ... so what to do
                    #12 leave it on for some minutes and noticed that the relays mainly those lite orange was warming a little
                    #13 so I a get a point to focus
                    #14 measuring the relays saw that all coils was energized at around 5v
                    #15 another mistake, and here is where you need be patient and understanding before starting soldering/desoldering ... i decide to remove the relays (this was a error, and that was a mistake
                    #16 ohms went high to 800ohms, now appears good
                    #17 but, why the relays was energized? I discovered that those sot23 that was connect to 0v and to the coil, was shorting the 0v rail and as the 5v rail was connect direct to the other side of the coil relay it was causing the relay been energized
                    #18 another big mistake ... looking on the sot23 it had a marking code 2A and a letter E turned 90 degrees ... some google and a found that was a N Channel MOS ... big, big ... big mistake
                    #19 replaced those sot23 and the relays continued getting 5v on all coils ... so something wrong
                    #20 here again think before do ... course that would happens N Channel with 0V connect to the gate and relay connect the source and the other end of relay on 5V will act as diode and will energize the coils
                    #21 so, what now?
                    #22 remove the N Cnannel and soldered the PNP transistor, the multimeter worked
                    #23 Also a notice and this is very important the relays that are lite orange are what is called SRCRS relay with 2 coils (Set and Reset), what that means? means that they should not be energized, but, just send a pulse to switch the Set or Reset​
                    • pb1911nt
                      820-4924-A Runs suspiciously slow - what could you measure?
                      by pb1911nt
                      Hi
                      I have now a 820-4924 (with a i7 and 16GB).
                      I would like to get the device working again for me.
                      The Problem is the Device comes to me with a "dead" ssd. I tested on a other 820-4924 (i5-8gb) board and the MAC OS Installation stopped working with this SSD.
                      Well i hope/guess its was a easy peasy Fix - New SSD And its working again.. But No!
                      I don't know exactly how the procedure should start. But the LCD panel goes dark - then the "chime"(?!) sound comes and only 2 or 3 seconds later the apple comes.
                      it doesn't...
                      10-27-2025, 08:48 AM
                    • Khoja
                      Fluke 123 no image on the screen
                      by Khoja
                      Hello experts,
                      I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
                      When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
                      At this point, I'll have to try and fix it myself. Has anyone here...
                      04-10-2025, 09:24 AM
                    • edugimeno
                      How to correctly measure a mixed low&high current
                      by edugimeno
                      Hi there!
                      Im trying to determine the consumtion rates of a module Im testing. Particularly it's a Decawave DWM1001 module, which is expected to use around nanoamps during normal state so a LiFePo4 battery should last months
                      This module has peak spikes of around 100mA once a second, while the TX module is active, and then goes to sleep for the rest of the time (this is when the uA rates are expected)
                      But I'm having issues to measure this current.
                      1.-Using a multimeter. Obviously all I see is values jumping all the time, as this is not expected...
                      11-15-2020, 03:51 PM
                    • aandrade
                      PS5 Dialog DA9081 in power on measure pin EN with 0.5v
                      by aandrade
                      According to the image, pin EN should be 3.3V, and I currently measure 0.5V when turned on.
                      Does the 3.3V come from another line or is it generated by the DA9081?
                      Thanks!...
                      06-29-2025, 06:53 PM
                    • dansity
                      Power DeWalt 12V laser measure from power supply
                      by dansity
                      i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
                      However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
                      I want to power it from my PSU.
                      The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
                      i want to know what is the third pin exactly and what do I need...
                      10-29-2023, 03:04 AM
