trying to identify 10k Slide Potentiometer
  • ImpossibleRepairs
    • 27
    Hi Good peoples;
    trying to identify manufacturers of this slide Pot from a Flight controller;
    there is also an S W or M S printed underneath;
    Sorry I couldn't get a better picture;
    please and thanks as always
  • ImpossibleRepairs
    • 27
    Bumping;
    I have found a few very similar 2 channel pots that Im going to try and modify 🤞🏻
    • MendipEng
      Help to identify Tele-handler joystick potentiometer component.
      by MendipEng
      HI all.
      I am trying to identify the following component.
      It is a potentiometer of some sort.
      It has been removed from a Tele-handler joystick.
      I have never seen a component like it & dont know what its called to search for it.
      It receives a 9 volt DC supply then gives an output from 3-9 volts depending on position.
      I have multiple photos but the track inside is broken & needs replacing.
      The problem being that the machine is over 20 years old & no longer made, the manufacturer no longer exists and there isnt any replacement units available....
      08-27-2023, 03:46 PM
    • thesame
      DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
      by thesame
      Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
      The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
      02-27-2024, 04:31 AM
    • silver60618
      Lenovo Legion 7 - Help Identify IC
      by silver60618
      Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
      I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
      Any help would be appreciated...
      07-02-2025, 12:16 PM
    • chth96
      How can I identify varistor which have been blew up?
      by chth96
      I mistakely pluged 100v japanese retro game console to 220v outlet.
      So It seems that glass fuse and varistor have been blew up.
      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
      Is there any way to identify varistor type in my sega saturn PSU?
      Any reply would be appreciated.
      EDIT:
      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
      11-26-2023, 08:52 AM
    • freakorio
      Need Help To Identify Component on Ymain LJ41-05120A
      by freakorio
      Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
      05-21-2024, 02:32 AM
