Help Identifying this chip - 324
  • cook
    Quiet observer
    • May 2010
    • 100
    See the attached drawing of the chip I am trying to identify. I think the last character (the 'H') may actually be the manufacturer logo, but I am not sure.
    This chip is part of a hand held device that detects metal. Its called a pinpointer, and is used in the metal detecting community. The chip is located on the main power rail which is from a 9 volt battery, noted in the drawing.
    I tried many searches to find the part, but did not see anything that looked close. But then I have very little experience doing this and I could have easily missed something obvious.
  • mon2
    • Dec 2019
    • 14691
    Single comparator of LM324 type ?
    • cook
      Quiet observer
      • May 2010
      • 100
      Also..... Is the 'H' with the line above it and below it actually a logo? If so, what manufacturer uses it?
      • cook
        Quiet observer
        • May 2010
        • 100
        Thanks mon2. I will head in that direction with my searches.
        • truclacicr
          • Apr 2019
          • 352
          • australia
          FDC6324L -- Integrated Load Switch
          https://www.onsemi.com/download/data...fdc6324l-d.pdf (datasheet)
          https://pl.aliexpress.com/item/1005006648645475.html (photo)
          http://markingcodes.com/search/c/324
          If you suspect that this chip is bad, you may be able to bypass the switch by connecting Vin to Vout. This would enable you to verify the rest of the circuit.
          • cook
            Quiet observer
            • May 2010
            • 100
            This is great!!! Thank you truclacicr!!
            • harp
              • Jun 2022
              • 644
              • Planet Earth
              There is dedicated forums for metal detecting like geotech1 forum, with worldwide members with lots of information and knowledge.
              When searching, first type the package name folowed with first part of marking code, in your case try: sot23-6 marking 324
              Then go to image tab and look to see some pictures with 6 leg stuff with marking 324.
              Last character is date manufactured or so... ignore that.
              • mon2
                • Dec 2019
                • 14691
                Excellent find! Great teamwork.
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                • Loki_Fido
                  Requesting help identifying chip in Macbook Pro A2485
                  by Loki_Fido
                  Hi ya folks,
                  I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
                  It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
                  I replaced it and the SSD are fine. No more shorts.
                  But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
                  But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
                  Chip marking...
                  08-07-2025, 10:17 PM
                • skdsp
                  Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                  by skdsp
                  I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                  Attached is the photo.
                  Thank you!
                  09-27-2025, 09:05 PM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
                • trepachka
                  Help identifying this chip for Yoga 7 16IRL8
                  by trepachka
                  This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
                  A photo of the chip is attached.
                  Thank you....
                  06-22-2025, 11:13 PM
