Recommended chip programmer for eeprom etc.
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    I keep seeing people in the Tv forum asking for eeprom programming and a lot of them seem to use a CH341a.
    Is there a reason why this seems to be so popular? Or are there better and preferable alternatives?
    Are there ones which a novice would be better off using?
    Any suggestions welcome.
  • lotas
    • Jan 2016
    • 4668
    • Russia
    Here on the forum they often confuse spi flash with eeprom.
    Eeprom is episode 24 (24сxx...), Spi flash, spi nand is episode 25 (25xxxxx..).
    CH341A is a simple programmer, if it is black, then it needs to be modified even better (green, the old ones do not need to be modified).
    If there is something more serious, then these are programmers RT809F, RT809H, XGecu T48, XGecu T56, but they are several times more expensive.​
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      Which one do you recommend Lotas? As the king of the programmer😁
      Edit. I just looked on aliexpress. The RT809F is £7.49. But on Amazon or eBay 10x that price. Should I chance the Aliexpress one?
      • Repairtechlcd
        • Nov 2013
        • 12
        • Malta
        RT809H is quite good and that what I use. But there are even better ones if you have the money.I have heard about UFPI programmers and heard a lot of praise about them
        but never seen or used them so it's only hearsay on my part.Wonder if anyone here on the forum uses them.Would be very interesting to hear their take on them.
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          What is supposedly so much better about the UFPI programmers as opposed to RT809H?
          What is easier/better about it? Does one solve more problems than the other? Etc.
          • lotas
            • Jan 2016
            • 4668
            • Russia
            Yes, UFPI is a good programmer, it cannot be compared with the RT809H, I use one myself, here is their website.
            https://mslw.com/ufpi/​
            • Donny2derby
              • Apr 2023
              • 228
              • Uk
              Ok Lotas I don’t think I need to be spending a grand on my first programmer. I probably will go the CH341a to begin with because I truly don’t have the first clue about how to use them.
              How often in TV repair is a programmer needed to produce a working set?
              When do we know we need a programmer?
              For example is PSU is ok, T-con board has 12v and the Vcc/VGH/VGL is all ok, is the next stage to test the eeprom? Or is it often wise to check the eeprom in first stage of fault finding?
              Thanks.
              • Repairtechlcd
                • Nov 2013
                • 12
                • Malta
                Holy crap that's one hell of a programmer. it's miles ahead of the RT809H. Thanks for posting the user manual.When I have time I will look through it
                thoroughly​ but just scrolling through it show that this is a very serious bit of kit.
                  • 31090
                  just gonna give you a warning,
                  most programmers cant program 1.8v chips without adapters.
                  ALWAYS check the datasheet for a chip before you try to program it so you know the supply voltage.
                  CH341 can only program 5v and 3.3v without adapters,
                  the T56 can program anything.
                  but a T56 costs about 70x as much as a CH341!!!!
                    • 31090
                    what is this?
                    https://mslw.com/product-category/ufpi/activations/
                    is this a scam-product like all the CANBUS tools?
                    • Donny2derby
                      • Apr 2023
                      • 228
                      • Uk
                      And most TV’s have a 1.8v power rail yes? So do most TV’s have chips running on 1.8v that often need to be programmed?
                      • harp
                        • Jun 2022
                        • 606
                        • Planet Earth
                        what is this?
                        UFPI Red supports eMMC in 8-bit mode.
                        Licenses activated in this programmer by default:
                        1-Wire
                        EEPROM I2C
                        EEPROM SPI
                        EEPROM Microwire (3-Wire)
                        SPI Flash
                        UART
                        SD/eMMC
                        NOR
                        NAND
                        Serial NAND
                        OneNAND
                        BDM
                        JTAG
                        Mount chip activation, mount file activation and LOGGER module activation, if necessary, are purchased separately.
                        Details of all included UFPI modules and licenses can be read here.​
                        https://mslw.com/ufpi/licenses/
                        • Donny2derby
                          • Apr 2023
                          • 228
                          • Uk
                          I’ve ordered the basic model CH2341a. I think this is best place for me to start.
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                            by SMDFlea
                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                            and once you do find them there`s a few crucial steps missing.
                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                            After adding the chip save the xml file and copy it to the root directory of the...
                            05-26-2024, 07:15 AM
                          • hotcrossedbuns999
                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                            by hotcrossedbuns999
                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                            3. I could only locate two chips that look like bios chips. Could someone verify this
                            01-03-2025, 12:32 PM
                            Common SPI bios chip programming Questions and Answers
                            by SMDFlea
                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                            A: If you can`t read from it how do you expect to write to it ?.
                            Q: Why is my bios chip unreadable ?.
                            A: The programmer is faulty or has a worn or broken zif socket.
                            The USB cable is frayed,connector pins worn or some other physical damage.
                            Not enough amperage or voltage to power the programmer properly.
                            Bad...
                            09-02-2021, 04:40 PM
                          • intelg
                            HP Elitedesk 800 G6 lost BIOS admin password
                            by intelg
                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                            Here is the hardware identification specs:
                            HP EliteDesk 800 G6 Desktop Mini PC
                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                            Born on date: 07/26/2021
                            SN MXL11841GN
                            SKU 3X8V9UCHABA
                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                            SYSTEM BOARD ID 8710
                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                            11-03-2023, 02:05 AM
