Can anyone help me find this component marked SYV836 ?
  • bogosort
    • May 2022
    • 78
    I am trying to repair a laptop and I found the chip in a schematics.
    However, I cannot find anything when trying to search for SYV836.
    Can anyone help me find this chip so I can buy it, please?
    Thank you
    Click image for larger version  Name:	Capture.png Views:	0 Size:	316.2 KB ID:	3229811
    Last edited by SMDFlea; 03-06-2024, 01:36 PM. Reason: Added "marked SYV836" to thread title
  • truclacicr
    • Apr 2019
    • 299
    • australia
    I can't find anything either, but I expect the chip is made by Silergy.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Is that the same that is written on top of the IC ? Are there other markings ?
      • Francesc V.
        Diode marked as "E57".........not able to find it by reference
        by Francesc V.
        Hi:
        I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
        I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
        It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
        Any idea? it's a 6.6V zener?
        06-14-2025, 09:56 AM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
      • Yanleb
        Samsung UN58TU7000F no picture
        by Yanleb
        I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
        What is frustrating is that there's no voltage test point and no component labelling of any kind.
        What I have found so far:
        1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
        2. Voltage...
        01-19-2023, 01:44 AM
        Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
        by sam_sam_sam
        This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
        Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
        07-07-2024, 02:34 PM
