Has anyone ever used this device Upgraded 60A Solar Charge Controller, Black MPPT Solar Panel Battery Intel
    • Jul 2011
    • 6039
    I am interested in knowing if anyone has used this device before and if so what did you think about it quality and how easy is it to use
    https://www.ebay.com/itm/22579992865...Bk9SR6SJxsu-Yw
  • truclacicr
    • Apr 2019
    • 315
    • australia
    I don't believe this is a genuine MPPT regulator. A genuine MPPT controller would show the voltage and current produced by the solar panel as well as the voltage and current at the battery.
    BTW, you can truncate eBay's tracking garbage.
    https://www.ebay.com/itm/225799928657
    • redwire
      • 3907
      PREVIOUS model was shit - crappy caps, garbage heatsinking for the mosfets and quirky software.
      https://goughlui.com/2020/06/05/tear...0-30a-versions
      "Upgraded" must come with a lucky rabbit foot, no idea what they might have improved. That eBay listing is overpriced, they are reselling from china.
      • truclacicr
        • Apr 2019
        • 315
        • australia
        The example in that review is a PWM controller, not MPPT.
          • Jul 2011
          • 6039
          Thanks for the info I appreciate it I had a feeling that this was a to good want a be item and not worth a crap I am looking to buy an inexpensive one but I want a decent low amperage unit for the solar panels that I have 60 amp would be nice for what I want to do with it
            • Jul 2011
            • 6039
            The person who did this review was very thorough about the process he used to test these units
            What I basically got out of this review was that the build quality is fair at best and uses of using used parts in a new product is to me is a questionable practice at best but this is one case you get what you are paying unfortunately you are not told what you are actually getting for what you are paid for this device
            Thank you for sharing this review this helps me a lot
              • Jul 2011
              • 6039
              This brings me to this question about what is a good basis “ MPPT Controller ” for a descent quality and for a descent price level
              I would want something that could easily do 30 amps without having any issues the highest amperage that I would be using is less than 60 amps right now I only have two identical solar panels that I want to use for this project
              I want to do two things one is to get educated on this subject and do a proof of concept for something that I have been going back and forth about weather or not it is feasible to do or not or just maybe use something like this instead of a MPPT Controller
              1500W 50A Adjustable Step Down Module Stabilized Power Supply 25-90V to 2.5-60V
              Can be found here on eBay
              https://www.ebay.com/itm/225906237466
              Let me know if this is a good choice or not
              I am wanting to build an adjustable solar battery charger for my shed which is my workshop
              The main goal is to have a very stable solar power supply system that I can rely on I know that it mostly depends on how much sun you have and what time of day it is I completely understand this limitation it is what it is and can not control this aspect of parameters but I can control everything else by the choices that I make with how I control the voltage and current going to the battery cells but I just need a very stable power supply that is controllable
              I already have the battery charger controller which is really a battery testing machine modified to do only charging function only which can be hooked to my computer so I can keep track of the battery condition and the charging curve and how efficient the system setup really is
              The battery testing machine uses a 24 volt power supply so the power supply output is going to be set for something like 12.00 to 24 volts because the battery testing machine controller has a 12 volt regulator that supplies the power for the controller
              So if I an only doing 4.2 volt battery cells I can set it to 12 volts and if I am doing more than 2 battery cells then I can adjust the voltage accordingly to the amount of battery cells that I going to use but the highest battery voltage can only be to 24 volts but it really is one battery cell less for best results which in reality is a 20 volt battery pack
              One note about this battery testing machine is that it says that it can do 30 volts but only in the discharge charge mode but I am not really sure if that is the case or not in reality it probably more like 24 volt battery pack and that is it
              • truclacicr
                • Apr 2019
                • 315
                • australia
                Here are fake MPPT controllers:
                https://www.youtube.com/watch?v=rHdpE6Z0Z5U
                https://www.youtube.com/watch?v=vdIf8IN58oo
                https://www.youtube.com/watch?v=TIAIr8fkYX4
                • truclacicr
                  • Apr 2019
                  • 315
                  • australia
                  • samtron786
                    Solar Controller MPPT 100A
                    by samtron786
                    I have ordered such a solar controller MPPT 100A
                    my problem that goes off every now and then
                    At the beginning it worked very well and now the battery is 12.8 V sometime will be switched off
                    many thanks
                    https://de.aliexpress.com/item/10050...0.0,pvid:93691...
                    04-08-2021, 02:16 AM
                  • Techie_hobby1
                    Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
                    by Techie_hobby1
                    Need some help please with a few components on this small board so that I can troubleshoot the circuit.
                    The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
                    J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
                    J2 - to DC Output
                    J3 is Battery cell connector
                    however I am struggling to identify if:
                    Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
                    07-24-2025, 12:43 PM
                  • eccerr0r
                    Sell or Shim Solar panels?
                    by eccerr0r
                    Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                    However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                    So now what to do with these small panels?
                    I could sell them...
                    Or I could shim them....
                    03-29-2025, 01:07 AM
                    LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                    by sam_sam_sam
                    I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                    Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                    Pictures will come later when I have the lighting fixture gutted and have the battery...
                    08-11-2024, 11:10 AM
                    Ring Doorbell Solar Panel Battery Pack Modified
                    by sam_sam_sam
                    I bought a Ring Doorbell 2 during Black Friday sale for my drive way but there is no wall outlet near unless I drill a hole in wall
                    So I did a google search and found they have a non vendor solar panel and a battery pack but the reviews all said the same thing about about the solar panel connector going to the battery pack that it is easily broken because it is made on plastic circuit board which is very thin the battery pack is a hole another story in it self
                    The batteries are a non brand battery that I have never heard of but the battery case was done very nice in...
                    12-09-2019, 05:02 AM
