capacitor in circut, powered up
  • 13919
    • Jan 2014
    • 11
    On a energized power supply will a capacitor voltage read the same on both leads? I have a dead power supply and I m trying to locate the bad area.
  • selldoor
    Slow Learner
    • 7870
    Re: capacitor in circut, powered up
    Why not open a thread for it in a relevant section - post pictures and we will suggest
    some tests
    • 13919
      • Jan 2014
      • 11
      Just seeking some general knowledge. With a capacitor just conditionig voltage I was thinking that the voltages would be the same and wanted to find out if I was wrong about this.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        I'm not quite understanding the question. Are you asking if the voltage will be the same if you reverse the probes on your multimeter?
        • 13919
          • Jan 2014
          • 11
          Taking the probe and contacting the capasitor leads one after the other while leaving the ground lead on the frame.This is on a hot circut. What kind of reading should I expect.With my 40 yr old training my basics really suck.
          • Uniballer
            • Jul 2013
            • 334
            It theoretically could on the primary side of the supply, but most likely will not.
            Voltage across an individual primary cap could be as low as 170VDC, or up to about 400VDC if the PSU has active power factor correction.
            • 13919
              • Jan 2014
              • 11
              Would the voltage be the same in and out????12v in 12v out or would they differ. 12v in nothing out ,I would assume would be bad.
              • mariushm
                • May 2011
                • 3799
                The capacitors have a negative side and a positive side.
                If you want to measure voltage on capacitor, you can put the probes either way, the multimeter will measure the voltage difference between the two terminals. So, if you put the probes the other way around you'll just see the voltage with a negative sign on the multimeter screen.
                You can't test if a capacitor is good by checking voltage on each side, it's not working like a resistor in the circuit.
                In electronics electrolytic capacitors are almost all the time connected between the + and - of a power supply to store energy. They're not "in series" like a resistor. If you put a capacitor in series, that capacitor will only let AC move through it and DC will be blocked.
                See this for something that will make you understand easier : http://electronics.stackexchange.com...citor-block-dc
                later edit as you added a few posts while writing this:
                On the secondary side, most power supplies tie the negative side to ground... the power supply is earth referenced. So if you put one probe on earth or chassis and the other on the negative side of the capacitor you would measure 0 or close to 0, with the probe on + you would measure the output voltage.
                On the primary side, where those large capacitors are, it's a bit tricky. Often, that section is "floating" or in other words, not referenced to ground. The two AC wires from the socket come in a bridge rectifier and get converted to DC and you get a virtual ground (the -) and the virtual plus (the +) ... there may be no connection between the chassis and that - on the primary side.
                • 13919
                  • Jan 2014
                  • 11
                  OK Now I get it,took a while. Thanks for the remedial electronics lesson. I needed it.
                  • chth96
                    What capacitor should I purchase for Power Supply of obsolete game consoles?
                    by chth96
                    hello.
                    I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
                    It hardly ever freezed after I finished to recap all of caps in the power supply.
                    But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
                    To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
                    It seems that quality...
                    10-01-2024, 08:14 AM
                    DVR camera recorder switching power supply capacitor failure really
                    by sam_sam_sam
                    These cheap non brand capacitors at it again
                    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                    Well at least I have the cameras back on line I to try the...
                    01-22-2022, 06:28 PM
                  • r2digital
                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                    by r2digital
                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                    04-18-2024, 03:50 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
