How to fix "Err EEPr" error in Fluke
  • fluzocapacitor
    • Jan 2024
    • 6
    • Spain
    I own a Fluke 117 multimeter, and suddenly it started displaying "Err EEPr" when turned on. What puzzles me is that the error is not permanent; sometimes it works fine.
    Do you know what could be wrong with the multimeter? Any tips on how to try to fix it?
    Regards,
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    EEPROM error​
    • CapLeaker
      Leaking Member
      • 8153
      Take the EEPROM out make various reads and verify the content. Buy a new EEPROM and copy the data to it, solder it it and pray she comes back to life. Clean the DMM inside while your at it.
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • Maalobs
        Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
        by Maalobs
        I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
        The relevant service manual for the chassis is available here.
        The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
        When I short the SDM to ground I get the layer-2 error code 53.
        The inside of the TV has no damaged components and no swollen capacitors.
        In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
        04-02-2019, 01:15 PM
      • medinfo
        Mac T2 after update(There was an error activating your device)
        by medinfo
        Macbook Pro 2019 T2
        iCloud OFF
        MDM unlocked by changing Serial Number
        worked fine but after latest update see (There was an error activating your device. Please try again).
        Erased and boot in internet recovery, same error.
        changed to original serial number (iCloud OFF & MDM ON), same error.
        tested with others serial number, same error.
        tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
        Revived and restored by Apple Configurator and same error.
        Any help ?
        12-31-2023, 02:04 PM
