I am trouble shooting a Celestron Hand Controller and do not know what this part is. It appears to be marked E6H -located to Right of O chip under U12. Any ideas?
What is this SMD marked E6H
"ELM7SU04B is CMOS unbuffer inverter IC". Marking is E6x.
https://www.elm-tech.com/en/products.../elm7su04b.pdfComment
Thank you - I searched the part and reviewed the data sheet. I cannot find the part at any of my normal sources - or anywhere for that matter. I am not too sharp here, but it appears a Toshiba TC7SU04F may be an equivalent. I asked Bing AI and it puked out nonsense and an answer of "no". Any thoughts?Comment
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
09-10-2025, 10:20 AM -
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by Francesc V.Hi:
I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
Any idea? it's a 6.6V zener?
by ManiackkHello,
Device: PocketBook InkPad 3
Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
I would appreciate help identifying this component.
Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...2 Photos -
by klynstronicHello. Does anyone know the code for this regulator marked H50A A121?...1 Photo
- Loading...
