Regulatory code marked as H50A
  • klynstronic
    • Jun 2022
    • 45
    • españa
    Hello. Does anyone know the code for this regulator marked H50A A121?​
  • truclacicr
    • Apr 2019
    • 352
    • australia
    Could it be a 5.0V LDO regulator?
    • R_J
      • Jun 2012
      • 9610
      It might be a LN1131
      • klynstronic
        • Jun 2022
        • 45
        • españa
        Hola, gracias por tu respuesta. Si es un regulador de 5 V y la distribución de pines coincide, 300 mA son suficientes. Gracias, se acerca bastante.
        Google translate - Hi, thanks for your reply. If it's a 5V regulator and the pinout matches, 300mA is sufficient. Thanks, that's pretty close.​
          SMDFlea commented
          Editing a comment
          This is an english language forum !!!!
      • lotas
        • Jan 2016
        • 4814
        • Russia
        Marking Rule, Output Voltage Range(V)
        • klynstronic
          • Jun 2022
          • 45
          • españa
          Okay, thanks.
          • klynstronic
            • Jun 2022
            • 45
            • españa
            Hello. I write in English, so I don't know what the problem is.
            • truclacicr
              • Apr 2019
              • 352
              • australia
              Try to identify the ICs that are powered by the regulator, then examine their datasheets. That should tell you what voltage they expect.
              • klynstronic
                • Jun 2022
                • 45
                • españa
                Hi. Thanks for your reply. That's the first thing I did; it's also printed on the motherboard. It's 5 volts output, thank you.​
                • klynstronic
                  Help to identify the component code marked as .11.
                  by klynstronic
                  Hello. Could you help me identify the code for this component marked .11?
                  It belongs to the BMW X1 automotive gear selector circuit.​...
                  04-18-2025, 10:24 AM
                  LCD LED TV Service Menu Codes
                  TCL LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  10-31-2024, 03:58 AM
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
                • Geosphere
                  Help identifying SOT-23-5 regulator marked BFCV on Lucky Miner LV06
                  by Geosphere
                  I’m trying to repair a Lucky Miner LV06 Bitcoin miner that was given to me.
                  It looks like someone plugged 12 V into the 5 V rail and fried the three small adjustable regulators.
                  Each regulator is a SOT-23-5 package, all marked “BFCV.” I can’t find any datasheet or reference to that code. The regulators appear to generate 3.3 V (for ESP32), 1.8 V, and ~0.8 V (for the BM1366 ASICs), set by resistor dividers?.
                  From tracing the PCB:
                  Pin 1 (red) → 5 V in
                  Pin 2 > GND
                  Pin 3 (yellow) > output ...
                  09-19-2025, 12:24 PM
                • Sorrow1
                  Intergraph TDZ 2000 mainboard post code 2F/2E
                  by Sorrow1
                  I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                  It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                  When I recorded video of POST card and played it in slow...
                  01-03-2024, 04:13 AM
