Diode Identification
  • O_Agios
    • Nov 2013
    Took a picture of a diode taken from a Philips Monitor 24" PCB
    Looking to identify it please.
  • harp
    • Jun 2022
    • 648
    • Planet Earth
    B5100C 100v 5A
    • O_Agios
      • Nov 2013
      Thank you.
      • hobostove
        Corsair RM1000e - Help identify 5VSB Zener diode
        by hobostove
        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
        There's a 22ohm resistor that's melted and open, but it still has the bands.
        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
        It looks like the diode connects the source and drain of a TNY284...
        03-27-2025, 02:25 PM
      • jjne
        AUO M270QAN01 - identify diode?
        by jjne
        I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
        Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
        ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
        01-24-2024, 08:39 PM
      • jezzaaaa
        Identify replacement diode
        by jezzaaaa
        I'm trying to find a replacement diode for one that has gone short.
        I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
        I can't find the exact part number for sale. Similar...
        05-09-2023, 11:26 PM
      • gurj1979
        Ubiquitiu 24 port POE. Help Identify Diode 3pin)
        by gurj1979
        Hi again guys.
        Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
        I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
        Anyone help me identify the model of this Diode ?...
        08-23-2023, 08:39 AM
      • MrBojangles
        Diode identification for data rescue
        by MrBojangles
        Heyo
        I'm trying to perform data rescue on this drive and don't want to make a mistake. I've found a burned diode and a shorted capacitor right next to it. I've found a component on eBay that seems to match up. Can someone confirm please? Also I don't mind replacing it with a compatible component if it's easy to get hold of.
        https://www.ebay.de/itm/235070605065
        Have a nice day
        05-29-2025, 03:16 AM
