It has an "S" and "32" on the back of it. I pulled it from my vhf mic and it's testing bad. I dont know which new one to purchase because i don't know what to go off of. Can anyone tell me how to find the type and size of it?
Which tactile switch is this?
That is a very common (6mm) right-angle PCB mount tactile switch. Everyone makes one, critical is the button length. Some manufacturers spec H to the middle of the switch, not the back, so be careful.
My last order of some was Aliexpress Javino Store and I was happy with them. E-Switch melt too easily, Omron is the best quality.
Ok. On digikey i see they include voltage and amps in their descriptions. Should i consider this?That is a very common (6mm) right-angle PCB mount tactile switch. Everyone makes one, critical is the button length. Some manufacturers spec H to the middle of the switch, not the back, so be careful.
No, it is not important because these switches are only used for low power. The button length and mounting pins (2 or 4) are important to check.
Filter: Mounting Style, Through Hole, Right Angle.Last edited by redwire; 12-06-2023, 07:22 PM.Comment
So on Digikey, I'm assuming H = Actuator Length, Right Angle in the filters section?Last edited by Jackching; 12-06-2023, 08:46 PM.Comment
Has anyone seen something like these switches?
The base is not plastic but of a PCB board. Instead of legs, there are 4 semi-holes. The metal membrane has a hole in the middle. The button base (pcb) has in the center what looks like pads for a LED (unpopulated and at the moment can't really remember the exact trace routing ) hence the metal membrane with the hole.
The top button part is rubber and covers the whole base.
The switches are from a mid 2000 MAN truck (VAG).
The base size was something like 8x8mm or 10x10mm, unfortunately I forgot to measure them and currently are not with me.
Will it be possible to buy new ones?Last edited by madan1; 04-09-2025, 06:08 PM.Comment
I do not remember ever seeing replacements for this type of switch before and I cannot tell you how to search for them unfortunately
This similar thing but I am sure that they are exactly the same type
https://components.omron.com/us-en/p...witch_featuresLast edited by sam_sam_sam; 04-10-2025, 04:40 AM.Comment
This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 05:30 AM
by grimacelordHello,
I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need.... -
by SluggerBI have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,... -
by sam_sam_samPanel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
( needs more cam circuits for the machine to work correctly again )
https://www.ebay.com/itm/275321870186
To
3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
( not 4 positions but the right amount of cams circuits )
https://www.ebay.com/itm/274660439950
I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around... -
Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...13 Photos06-24-2024, 01:24 PM - Loading...
