Playstation3 YLOD repair and Silicon termal Compound Past
  • ivtec
    • Dec 2008
    • 1967
    Hi guys: have here an Old Play station3 that when powering up it go green for a second and the fan also turns on for a second then shuts off with red led blinking,
    http://www.youtube.com/watch?v=J5fzUrP0pxs
    i've already dissembled it so i want to try to do the YLOD repair,
    i have AK-100 Silicone paste can i use it or should i buy other type?
    Re: Playstation3 YLOD repair and Silicon termal Compound Past
    I may be mistaken but I believe a red light of death is different to yellow light of death and typically indicates bricked firmware or other hardware fault.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      bga failure.a reflow may work a while.
      a reball a bit longer.
      • Woodsworth
        PS3 CECHC03 60GB YLOD Troubleshooting
        by Woodsworth
        I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
        START
        Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
        03-19-2024, 07:58 AM
      • eniac22
        Burned IC Silicon Power SSD
        by eniac22
        I have a burned IC on a Silicon Power SSD S55 240GB. The marking of the chip is KW7YD.
        I can't find any info for this chip, where can find the same or compatible?...
        12-06-2023, 07:42 AM
      • BustinCaps
        Dell 2007WFP resistors under white silicon blog
        by BustinCaps
        My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
        04-29-2022, 06:19 PM
      • paulstevens
        White Compound on Electrolytic Caps
        by paulstevens
        Hello, what is the white compound used to "glue" capacitors down to a board so they don't vibrate? Is it RTV? Does it have an official name or function?
        What I am really asking is what can I use to replace it when I find it broken or cracked on boards I am looking at.
        Thank you.
        01-31-2023, 09:41 PM
      • Xenon-Codex
        Silicon image Sil3114 bios update
        by Xenon-Codex
        Does anybody have update for these? It does not support over 500GB HD's.
        AM29F010 memory chip.
        I found some but those didn't work....
        05-20-2023, 10:53 AM
