White Compound on Electrolytic Caps
  • paulstevens
    • Jan 2023
    • 13
    Hello, what is the white compound used to "glue" capacitors down to a board so they don't vibrate? Is it RTV? Does it have an official name or function?
    What I am really asking is what can I use to replace it when I find it broken or cracked on boards I am looking at.
    Thank you.
    • 31283
    Re: White Compound on Electrolytic Caps
    it's neutral-base rtv
    be carefull because the cheap stuff sold for bathrooms is either acid-base or alkaline-base and will do damage.
    you dont really need it.
    • paulstevens
      • Jan 2023
      • 13
      Thanks. I'm working on a Yamaha RX-A3050 and have the Digital PCB out. The RTV securing one of the two giant electrolytic caps on the power board has cracked, and I can rock the cap back and forth. I was planning to remove the power board to verify the solder joints of that cap (and the others) and wanted to fix it right, hence the question about the RTV.
      If I don't need it I probably won't bother with it.
      Why is it there? To keep them secure during transportation? Or some functional reason?
      Thanks.
      • andrewsawesomr
        • Jun 2022
        • 101
        • United States of America
        It's usually there to prevent cracked solder joints/damaged components from occurring during the shipping process or from vibration from something like a transformer.
        • diif
          • Feb 2014
          • 6978
          • England
          It's also added to aid in manufacturing, holding components in place for soldering.
          • paulstevens
            • Jan 2023
            • 13
            Thanks everyone. I appreciate the help and info!
            • Galraedia
              • 7
              It's non acidic silicone glue. You can find it on places like eBay using terms such as "thermal adhesive" or "heatsink plaster". It's used to hold components in place, insulate them from dust and moisture, and used as a thermal adhesive between chips and heat sinks.
              • madscientist750
                Replacing electrolytic caps by solid caps on old motherboards
                by madscientist750
                I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                10-19-2025, 06:10 AM
              • Perry Babin
                How do organic polymer caps compare to liquid electrolytic for reliability
                by Perry Babin
                I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                If not organic polymer, what would be the caps that could take the most abuse?
                08-18-2025, 04:04 PM
                MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-06-2024, 07:46 AM
                MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-06-2024, 07:29 AM
                MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-06-2024, 07:25 AM
