Digital Torque Wrench Adaptor
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Anyone have any experience with these ?
    Supposed to turn any socket handle into a torque wrench
    Powerbuilt maybe the originals, several brand-X versions now on offer
    Any of them any good ?
    Any recommendation or veto ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Digital Torque Wrench Adaptor
    oh! what the fuck!? They actually make these?
    I think I will have to get one, I need one in 3/4 drive up to 200 ft/lb
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      This http://www.alltradetools.com/catalog...6-940759-.html is what I suspect is the original
      Are they, or competitive products, any good ?
      • JJR
        • Mar 2013
        • 171
        Personally I don't see the point of these devices.
        I can buy one of these http://www.bennetts.com/torque-wrenc...170-684405.php for around £50
        Or i can get a real quality torque wrench like this http://www.screwfix.com/p/teng-tools...e-wrench/22796 for £55
        No contest
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I was considering its potential to check calibration of torque wrenches
          But not much point if the electronic adapter is a P.O.S.
          Hence the question
            HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
            09-06-2024, 08:50 AM
          • Simonc123
            CH341A bios chip wont fit 1.8v adaptor holder
            by Simonc123
            Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
            Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
            03-09-2025, 08:54 AM
          • wolf1976
            is there any univarsal wifi motherboard that supports and digital tvs ?
            by wolf1976
            hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
            is there ?
            do you have to suggest me one ?
            thanks on advance...
            01-05-2025, 04:29 PM
          • ronelex
            Macbook Pro A1502 Adaptor Shorted When Battery Attach
            by ronelex
            Unit works on Battery Mode
            Unit works on Adaptor Mode
            But When Adaptor and Battery both attach, the charger plug overheat so much, when using PSU it draw 3A when battery is attach
            Checking battery connector when adaptor only attach, J7050 PPVBAT_G3H_CONN measures 12v- 0v- 12v cycle and the mosfet driving Q7155 pin 4 measures 5v then 12v cycle
            08-29-2021, 06:35 AM
          • Tarot Superstars
            How The AC stage of an Adaptor works
            by Tarot Superstars
            Hi. I have been watching videos on how a power adaptor works.
            There is explanation of the rectifier bridge to the pulse width modulator, the mosfet for switching, and opto-couplers, but there is little to nothing about the AC stage of the transformer the powers the primary coil.
            So, I see that the PWM needs DC to work, but I don't see anything about how the AC gets from the mains supply to the transformer stage.
            A transformer only works on AC so where is that part of the circuit.
            I only see Capacitors on the output. Should I assume that the secondary coil and...
            09-27-2023, 01:00 PM
