enermax liberty tripping gfci.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    My recently repaired ENERMAX Liberty ELT500AWT was working fine on normal unprotected circuits, but then I move the computer to my recently renovated shop (detached garage) Where code has required I use these gfci receptacles.
    Anyways when I try to fire up my rebuilt workstation, it trips the gfci. I thought bad cord or something wrong. I switched out cord with a new cord, tripped again. I tried a different circuit with a matching GFCI recep, tripped that one too. But then I went outside which has a weather-resistant gfci which is a different brand, didn't trip. Yes I did push the test button to make sure it works.
    I don't think there's anything wrong with the power supply, I've google it and it seems like it's a common problem for enermax PSU because of it's active PFC.
    Solutions?
    EDIT: also I am in the market for an UPS Battery Backup, so that could be a solution but I don't know what to buy that could stop this gfci tripping.
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: enermax liberty tripping gfci.
    did you check Y and X caps?
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      I'll be honest, when I say I don't know what you mean.
      I'll be an ass and assume that it's those blue thingyies near plug that bridge the neutral and ground.
      Also how do test them?
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Well I somewhat solved it.
        I replaced the gfci receptacle which was a leviton brand with a pass & seymour gfci, ($16 at Lowes). It works, just as long as I don't frequently restart/reset the computer, like overclocking which requires a lot of the "reset button" then it will trip. Hopefully when I get a battery backup it will somewhat help with the problem. But for right now It allows me get the computer up and running from a cold start.
        • Behemot
          • 4845
          • CZ
          There is always some loss in SMPS as part of the power is radiated away from the circuitry and catched by the grounded cover. I've read something about this, for that reason there should be these current protectors with built-in tolerance for several tens of mA (depends on exact type) or with slower reaction time intended for SMPS.
          Or just don't use it at all, this usually is usefull in bathroom or so for situations like using hair-dryer in bath.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Failed/insufficient line filter allowing RFI/EMI to backfeed into GFCI. "Donut" current transformer in GFCI picks up these currents, unbalanced to a point. This unbalance looks just like a ground fault to the opamp/comparator, and the device trips.
            Such RFI/EMI varies with load, and as you've found, "rapid resetting" trips the GFCI.
            Partially correct. A 4700 pF line-to-ground cap (of the two) has an XC of about 560k ohms at 60 Hz. This allows about 214 microamps to flow. This is the so-called leakage current when dealing with EMI filters. This current occurs because of line voltage and capacitive reactance of the device.
            The noise current is not trying to "get to ground." It tries, with all parallel paths, to go back to its source, namely the common point of the DC bus.
            This can be the "film cap" after the rectifier in a PFC booster, the electro(s) in a flyback or forward converter, or the center tap of two electros in the case of a half bridge.
            That return path is not perfect nor can such noise be easily controlled. Hence common mode chokes, forcing these currents back to the supply common by presenting a higher common mode impedance up the line cord than back to the common return.
            But in order to present a high impedance on the node which faces the power supply, the node facing the AC line must have a very low impedance (at high frequency). Hence the X cap across the "line side" of any common mode choke(s).
            If the X cap opens or loses capacity, the filtering action is greatly reduced.
            -There must be both X caps and common mode chokes.
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • Behemot
              • 4845
              • CZ
              There always are some losses, you cannot supress them to 0. Than it just depends on how sensitive GFCI is. And as I said, there should be some especially for SMPS, designed to tolerate some losses.
              • Nitro468
                • Oct 2013
                • 65
                GFCI receptacles have about a 10% failure rate... OUT of the box... Test them monthly..
                Any issues, change the outlet 1st..
                  Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                  by momaka
                  Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                  First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                  02-15-2021, 01:05 AM
                • vestaviascott
                  Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                  by vestaviascott
                  I'm looking for the dial cord winding settings for this radio!
                  I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                  The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                  06-07-2020, 08:36 AM
                • eigma
                  Enermax Tomahawk ETK450AWT PSU Repair
                  by eigma
                  A few weeks ago my computer power supply (Enermax Tomahawk ETK450AWT) stopped working. Of course this led me down a reverse engineering and circuit debugging rabbit hole ;-) I also learned about capacitor Equivalent series resistance along the way, and wrote an article about it all. Here are some sneak peeks:
                  And the full article:
                  https://github.com/cpatulea/src/blob...awt-psu-repair
                  Enjoy!...
                  01-18-2021, 09:14 PM
                • spleenharvester
                  Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
                  by spleenharvester
                  This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
                  Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
                  Cheers
                  12-16-2024, 03:36 PM
                • schnauzer2021
                  Chasis bond to neutral to overcome oven tripping problem
                  by schnauzer2021
                  I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
                  Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
                  I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
                  As I was too busy with my work, I leave it to the repairman...
                  09-13-2021, 02:40 AM
