Identification help
  • halldor89
    • Oct 2013
    • 6
    • Iceland
    Identification help
    Hi
    I've got an brushless esc (speed controller) that was plugged in with reverse polarity. Upon inspection I found a couple of chips that look toast.
    Can anyone help me identify them, looks like the markings say AL P11 but I can't find anything (see attachments).
    I also noticed some solder balls around the mosfets, what is that?
  • halldor89
    • Oct 2013
    • 6
    • Iceland
    Re: Identification help
    Anyone?
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      UGH, wow, that is some nasty, cruddy solder job!
      Those are probably schottky diodes but I had a look online and didn't find anything either
      Muh-soggy-knee
        Are those two diode connected in parallel? Is the Cathode (Banded side) connected to the incoming Positive input and the Anode connected to the Negative? They may be use as crowbar circuit protection in case the power input polarity was reversed.
        • Stanley1843
          BEST 505 Vs Mechanic Brand Reballing Balls with Lead
          by Stanley1843
          has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
          06-22-2024, 11:06 AM
        • corrize
          What are the 2 or 3 most used BGA balls sizes please ?
          by corrize
          Hello, I want to buy BGA balls (not stencils, only balls) but I don't know what size, it's just for reballing the new chip balled if the first attempt fail. So I will rarely use it. Probably chips are PMIC with max 60 balls. I don't need to reball EC chips from laptops of big chips like that.
          So what are the 2 or 3 most used BGA balls sizes I should have for cover the jobs please ?
          05-09-2024, 02:18 PM
        • Dev Goose
          Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
          by Dev Goose
          Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
          What Happened
          The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
          12-13-2024, 03:13 AM
        • Shulgin
          Acer predator XB241YU Component identification
          by Shulgin
          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
          I...
          05-11-2024, 11:06 AM
        • thebomb602
          ASUS GA402R IC identification
          by thebomb602
          Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
          also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
          EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
          11-21-2023, 02:30 PM
