LED Driving Lights
  • barry wilkins
    • Aug 2009
    • 172
    LED Driving Lights
    I want to make up some driving lights for my caravan . I bought a 1M strip of LEDS on ebay . One interesting thing I discovered ,if you overrun the LED,s they flicker ,looked to me that the LED,s actually switch off if they are too hot, this seems to happen about 14 volts .So when I get round to using them I will drop the voltage to about 10 volts.
    A guy who lives near has a white van with the strips just stuck on the front under the headlights and on the grill, but these are exposed ,and don't think that is very durable.
    So what I would like to do is stick the LED strip onto a length of aluminium to absorb the heat and then insert the strip into a clear plastic tube. If I fit this under a head light I need to bend the tube slightly , if I fit some just behind the front grill they could be straight.
    What I would like to know is how easy would it be to bend a piece of acrylic tube ?
    Would the heat from the LED,s give me a a long term problem with the plastic ?
    I am thinking of buying some tube off of Ebay in the next month to make a start on these.
    Barry Wilkins
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: LED Driving Lights
    those strips are a big joke.
    you should see the backup lights on a olds 442 i have been helping to restore.
    altilon 1x4 in each.
    daylight when you hit reverse.
    those could be used in driving lights too.
      master hoarder
      • May 2008
      • 12175
      +1
      The LEDs in the strip themselves aren't actually that bad, but to make them brighter, the manufacturers often "overdrive" them. Most don't last more than a few months, if even that much.
      Undervolting the strip to 10V won't help much either. The current-limiting resistors that they use in the strip are usually 150 Ohms. Each one is connected in series with 3 LEDs in series.
      If you want long life out of those LEDs, you would need to replace each current limiting resistor. I recommend at least 470 Ohms. But that's a lot of work.
      • gabrielA7
        IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
        by gabrielA7
        Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
        I saw that the room LED lights up only when the screen is connected, so quiet.
        We have all the power supplies, even processor, 1.8V
        One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
        I suspect that there may be some leak in the processor.
        Anyway, when I press the power, it...
        10-29-2024, 06:48 AM
      • Pipolups
        Corsair K70 LUX RGB dying LEDs
        by Pipolups
        Hi there !
        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
        10-08-2024, 11:58 AM
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • mikey5791
        Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
        by mikey5791
        Got this working ips led monitor by the brand of
        Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
        Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
        09-04-2023, 03:50 AM
      • cashkennedy
        Onn onc18tv001 with one bad led
        by cashkennedy
        I've had this ONN ONC18TV001 for about 5 years. My wife left it on 24/7 as a night light so not too surprised it broke where the screen was still displaying the picture just there was no Backlight. The power/mainboard had voltage for the back lights but when you turn it on it starts high over 100v then within less then a second would go down to 30 something volts if I remeber correct. I figured I should check for a bad LED since that's certainly a common failure on these. I did find one LED that I doesn't light up using the diode setting on my multimeter. There is one other thread about this TV...
        08-25-2024, 11:42 PM
