new American made incandescent bulbs
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: new American made incandescent bulbs
    I had one of those torch 300W halogens, those were bright...and hot...
    I was wonderring about those direct replacement screw in bulbs as Kiriakos was alluding to, which sounds like they do only use 70% of the power needed. How about color rendition index of these halogens, are they as good as incandescent or is the UV a bit more prominent? Annoying? Is it a frosted bulb or transparent glass?
    I do have a lux meter, which might be worth it to see how it behaves except I need to buy a bulb They don't appear to be cheap though, sometimes a crappy CFL will be cheaper...
    • cheapie
      null
      • Jul 2010
      • 849
      Originally posted by eccerr0r
      I'm tempted to go buy one of those halogen incandescent bulbs, anyone tried them? What do you think of them? Good enough compared to a regular incandescent?
      They don't quite give off as much heat though, so if you wanted a 100W heater, it's a bit lacking...
      They're okay, but I like the look of LED light better.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        I've had only fair luck with the incandescent halogens. The sylvania ones (which are also made in the USA) have a horrible lifespan. I use them in my porch lights....which have been in place since June. I've already had to replace 4 of them already (of 7). Now the GE/Edison halogens, I've had really good luck with those. They're made in Hungary. I've got some of those that have been in service approaching 5 years. I never jumped on the CFL bandwagon either....but I must admit I'm intrigued by LED's. CFL has all kinds of toxic obnoxious chemicals/components in them....not very enviro-friendly. LED, not the case....and they last seemingly forever.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          CFL mercury is less than that produced by burning more coal for an incandescent.
          However they never seem to last long (mainly the electronic ballast fails too quickly), have horrible buzzing when they are near the end of their life, and they take a while to warm up. Poor intermediate technology really. Can only wait for cheaper LED lamp.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            I've not had bad luck with CFL, most of them last as long as they say as long as they're not the really cheap ones and they're not turned on and off constantly. Also sticking non-dimmer ready electronic ballasts on a dimmer tends to kill them (ha).
            The number of CFLs that have burned out on me I can count on one hand, and virtually all the lamps in my house have been swapped to CFL (the remaining ones are my bathroom vanity bulbs, which I've started replacing as the tungsten bulbs burn out.)
            LEDs are still too expensive. Though it may be inconsequential and possibly outright weird, LEDs apparently need heatsinks. I hope they can produce multiwatt LEDs that don't need heatsinks someday (need to make LEDs with a lower Von?). Also the dimmer problem is oddly an issue for LEDs as well as they also have switching CC PSUs (in the flicker free, low LED count lamps). The LED lamps that have 40+ LEDs in them that are connected in series are probably less problematic but physically large...
            But to each their own, I'm surprised that E26-base halogens sometimes do not last as long as claimed. Also both LED and CFL have non-blackbody radiation, I'm surprised anyone would prefer either of these color outputs over incandescent (though honestly I can't tell, nor do I care as long as I can read resistor color bands. It's bad when I can't tell the difference from red/orange/brown...)
            • cheapie
              null
              • Jul 2010
              • 849
              EXACTLY! Don't turn a CFL off if you're only leaving the room for a minute.
              • satheesh1131
                American Megatrends Inc bios update for HCL ME laptop
                by satheesh1131
                I have a HCL ME laptop 2012 model. I need to update my bios which is American Megatrends Inc,(Current Installed Version - 211) to latest. Where can I find the bios update file or How can I download it?
                My Laptop Details:
                Manufacturer: HCL
                Product Name: HCL ME Laptop
                Version: 1.0
                BIOS Details:
                Vendor: American Megatrends Inc.
                Version: 211
                Release Date: 10/19/2012
                Address: 0xF0000
                Runtime Size: 64 kB
                ROM Size: 2 MB
                01-18-2025, 11:11 PM
              • elmontador
                LG RL4 (i made a mess)
                by elmontador
                Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
                09-02-2025, 03:31 AM
                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                by sam_sam_sam
                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • winbond
                american megatrend bios
                by winbond
                hello,
                kindly help to remove bios logo and password . laptop has no brand but the bios is for American megatrend
                SN/ 440121570280
                system manufacturer : Default strings...
                07-11-2025, 04:12 AM
              • handsworth
                Tv taping method made easy
                by handsworth
                Just wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
                02-11-2025, 09:07 AM
