OCZ Vertex 2 panic mode
  • luke10050
    • Mar 2013
    • 209
    hey guys, i have a 128gb ssd in panic mode... anyone have any ideas how to fix it? its not being detected by the BIOS and its clearly a firmware issue.
    Steps i have tried to fix it:
    Test in various computers - the Power and Activity lights stay stuck on.
    Desolder EEPROM - Well now i know its a firmware issue :P
    My next step would be to try and read the contents of the EEPROM and see what i find, might lead somewhere might not. it also has a TTL serial port but i dont have a RS232 to TTL converter so i cant use it.
    From what i understand i will either need to get the binary file somehow from the update utility or take it off an unbricked Vertex 2.
    Does anyone have any experience/help with these ssd's (its the old sandforce 12xx series with the sleep bug)
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: OCZ Vertex 2 panic mode
    well i just did a quick check and i couldn't do anything with windows updater (stupid downloader, typical)
    but there is bootable linux version that is 50mb heavy, i guess it includes firmware files inside, i couldn't extract it either on windows, but you can try burning it to thumb drive, booting up and check if you can then extract the dump
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Sounds like the board may be fubar.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • NSkyLab
        Toshiba 55SL417U looking for EEPROM and Firmware
        by NSkyLab
        Hello everyone, I described the symptoms and measurements here
        It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
        I'm not able to find eeprom and firmware dumps in open sources.
        Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
        01-20-2023, 12:29 PM
      • sofles
        Macbook Pro 16" A2141 screen artefacts, kernel panic
        by sofles
        Hi there.
        I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
        I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
        Now situation looks like this, If...
        02-05-2025, 05:05 AM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
