testing caps less than 1uF
  • shaunbt123
    • Nov 2012
    • 119
    • uk
    Hi there can someone tell me if there is a way to test capacitors below
    1uF i have a peak atlas esr meter but the minimum it will read is 1uF.i recently needed to test some caps below this value.
    thank you.
    shaun.
  • mariushm
    • May 2011
    • 3799
    Re: testing caps less than 1uF
    Capacitors under 1 uF are usually ceramic or tantalum capacitors. You don't find often the problems electrolytic capacitors have in these types of capacitors.
    Those capacitors either fall short and burst in flames (tantalums) or fall short or most often crack open (in case of ceramics).
    So check for those and when in doubt, replace them.. you can purchase rolls of 5000 ceramic capacitors for 10-30$ so few people waste time checking 0.1uF ceramic capacitors.
    • euromatlox
      • Mar 2013
      • 60
      • Finland
      Many cheap multimeters can read smaller capacitors, up to about a few microfarads. Also available are electric capacitance meters, which are better for capacitance only measurements (they can read very small pF caps and bigger uF caps too). There is also a pretty popular USB-powered measuring device for inductances and capacitances, see youtube video below.
      http://www.youtube.com/watch?v=cpxbwjDny0E
      • Mrx3750
        • Jul 2013
        • 311
        I have a capacitance meter. It doesn't test for ESR, but it reads capacitance from 200 pf, to 20,000 uf.
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          Adding to what mariushm posted, large form-factor SMT ceramic capacitors tend to fail leaky or short-circuit. The leaky ones can be tricky to diagnose, unless they are visibly cracked (burned through 1.5-2 man-days yesterday and the day before doing just that!). The shorted ones can be pretty nasty, suddenly glowing orange or cherry red when power is applied, sometimes severely damaging or destroying PCBs.
          Large form-factor SMT monolythic ceramic capacitors are evil! Necessary and unavoidable, but EVIL.
          PeteS in CA
            by momaka
            03-12-2025, 03:42 PM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
          • black6host
            Replacement caps for Samson Resolv studio monitor 65A Amp board.
            by black6host
            Good day!
            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
            I'm going to replace the caps and I'll be the first...
            02-06-2024, 08:22 PM
