House wiring issue
  • Hondaman
    • Sep 2008
    • 1079
    House wiring issue
    Okay, this is complicated. My house (built in 1964) is mostly wired with 12-gauge copper, 2-wires. But the outlets are 3-prong, and the ground prong on the receptacles is not hooked up to anything. There is about 10-12 volts between hot and the ground prong. Why?
    One room of the house has outlets that are protected by a GFCI in the circuit breaker box. When I place a voltmeter between hot and ground, there is about 50 volts AC. When I hook up the third (ground) wire (never hooked up before), I finally have 120 volts between hot and ground, like I should have.
    Any idea what is going on here? This is confusing.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: House wiring issue
    Your meter could be picking up stray voltage?
    Muh-soggy-knee
    • redwire
      • Dec 2010
      • 3910
      What I've seen happen is old 2-prong outlets get replaced by 3-prong, but the wiring is left alone and the box is not actually grounded.
      Your digital multimeter is sensitive, so it can give a reading on an ungrounded (floating) box. There is tiny capacitance and leakage current in the framing, all you need is 1-5uA to give you misleading readings.
      I had to add ground wires on outlets, or sometimes there is actually a ground conductor inside, it's just been cut off so you can't see it. I thought it was around the mid 1950's when house wiring went 3-wire in North America?
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        I didn't move into new houses all that often, but what I saw was polarized plugs came first. Around the late seventies and then in the eighties the three prong came along.
        I did in one case put a three prong outlet in an apartment once without hooking up a ground to the third prong. Only because it was an apartment. I wouldn't in my own house. I would go ahead and do it the right way. It's just apartment owners won't do it and would get upset if you tear up things to run new wires.
        sigpicThe Sky Is Falling
        • redwire
          • Dec 2010
          • 3910
          Apartment buildings follow different Building Code than houses - apt's must have wiring in metal conduit, which ends up grounding the boxes.
            I was helping my friend to find out if his outlet ground is connected to anything, I looked at the outlet box, they use 2-wire (Hot and Neutral), the metal outlet box has a copper wire attached to the box, the other end is attached to the Cold water pipe, so when you mount the outlet to the box, the ground on the outlet is grounded to the outlet mounting screws.
            There is one outlet that shows open ground, so I looked the pipe where the ground wire was attached to, I saw one section of the pipe was fitted with PVC pipe, so the ground is broken. They do not allow to use Cold water pipe for grounding any more, they run the 3-wire to get the ground back to the panel. Not good to depend on the pipe for grounding, the house was built in the 60's.
            • Hondaman
              • Sep 2008
              • 1079
              The computer room is the one protected by the GFCI in the breaker box (I just moved in, but it is going to be my computer room). The third wire was just hanging there, inside the box on all four outlets. I hooked up the third (bare copper) wire up to the outlet or to the box. Now two of the outlets work correctly, and two do not work at all.
              I rotated the four outlets to be "right side up". That's all I did, I swear. Why did power stop getting to two of the outlets? I have no explanation.
              I thought the GFCI in the breaker box was a "whole house surge supressor". No, it is not. When I get the brick on the chimney examined and repaired, I'll definitely ask about lightning protection. I want this house to last (built 1964, it's a pretty solid house).
              I'll call the professional electrician in the next week or two, and keep you posted. This is now beyond my skill level.
              • Hondaman
                • Sep 2008
                • 1079
                Oops, double post.
                • japlytic
                  • Oct 2005
                  • 2086
                  I've read about some older buildings in the US may not be wired correctly, particularly with respect to the ground wire - also, I have read that someone had to run their seminar with the audience in their socks because the computers were sensitive to power disruption because the venue did not have proper grounding of the mains outlets.
                  So this is why some UPS units (especially US ones) have included a Site Wiring Fault indicator.
                  • ugamazing
                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                    by ugamazing
                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                    12-17-2024, 07:05 PM
                  • Askic
                    Erratic touchpad behavior - ground issue
                    by Askic
                    Hello guys,
                    I'm having almost exact same problem like described here.
                    There is also a youtube video about this issue, but remedy suggested in the video doesn't help in my case.
                    When charger is connected, the touchpad starts with its erratic behavior. So it must be the ground issue. I'm not sure I understand exactly how to solve this.
                    Can you please have a look at the attached picture of the touchpad and suggest what to do exactly to try this solution?
                    In my case it is Acer M3 laptop and not Asus, but the symptoms are the same. Without...
                    08-19-2021, 03:44 AM
                  • shahnld
                    Lenovo legion 5 pro startup issue
                    by shahnld
                    Good day Experts
                    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                    08-24-2025, 12:31 PM
                  • ahmarzo
                    Acer laptop battery draining issue
                    by ahmarzo
                    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                    08-02-2025, 06:39 AM
                  • elmark
                    HP 15-cw1002ua strange keyboard issue
                    by elmark
                    HP Pavilion 15-CW1002UA
                    S/N 5CD0251CBC
                    P/N 7KE54EA
                    Hello guys!
                    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                    It powers on OK and has no other issues except the following:
                    • CAPS LOCK does not work at all
                    • Fn button toggles Flight Mode
                    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                    • (with SHIFT pressed: 't%' and 'y^' respectively)
                    I initially thought it was a keyboard malfunction (internal short, etc.),
                    but when I press and hold...
                    06-27-2025, 01:10 AM
