part identification
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    part identification
    can any one tell me if this is a fuse or a fusible resistor?,on my thread in tv section im repairing a lg19lu4010 lcd tv,everything is testing ok,just not sure on this part,on the board its marked "R111".but this part looks like a pico fuse??
    on continuity on my fluke 87v it reads open (OL)
    on resistance it measures (autoranging) 10.50 KOHM
    i hope the pics are good enough for you to see,i used a jewlers loupe and my camera phone.
    this part is inbetween the +of the bridge and the b+ of the smps transformer
    yes you do see the b+ marking on lcd tv power supplys and not just crt !(read a simular thread on here about the b+ not being on lcd psu's)
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: part identification
    pics
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      That's a 2A fuse. Littelfuse called that a Pico Fuse, though that particular may have been manufactured by Otto Heil (a European company).
      PeteS in CA
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        so would the "H" marking be a time delay fuse?it has confused me beacause the board legend said it was "R111"
        do these fuses when blown give a high resistance reading then, rather than a normal fuse showing open and no resistance reading?
          The 'H' is more likely to be the company icon. The resistance me be due the carbon track inside when the fuse link blown open.
          I have seen 3A fuse made by Belfuse that has almost 10 Ohms reading which should be less than 1 Ohm. I use PICO II fuse by Littilefuse for this kind of through hole fuse type. There should be fuse replacement warning printing on the board that will give the current rating, type, and voltage.
          I would inspect components after the fuse to see if it has any shorted components.
          • retiredcaps
            • Apr 2010
            • 9271
            Let's see a picture and the surrounding area.
            --- begin sig file ---
            --- end sig file ---
            • Duncanbest
              • Jul 2012
              • 81
              • Taiwan
              http://www.jprelec.co.uk/store.asp/c...Fuses---CF2470
              http://www.camdenboss.com/fuses-fuse.../2-4x7mm-fuses
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                brilliant budm,thats where my confusion was,the board marking said it was R111,yet the part said "2a" ,it looked like a pico fuse,marked as a fuse (on its self).i hate those little things they chuck in to confuse grrr !and not having a sch is frustrating too.
                @retiredcaps,il try my best with a couple of pics of the board camera not great though.
                the problem at its origin,a child banged the back of this set,the solder side of the psu managed to push itself against the rear of the metal lcd panel and caused a short at 2 points,there was no protection on the solder side to prevent this,very poor design as there is only about 5mm between the two!
                2 black marks on the panel itself,the shorts happend on the -of the bridge to the +of the bridge,this of course took out the T3.15A main fuse and the "R111",the bridge test is fine and most surrounding components are fine too.in the primary side.
                pfc is fine also,im getting 300+ volts at the filter cap,just no output voltages,need to test a few more components in the secondary,will get these pics up shortly.
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  ok problem fixed,lg19lu4010,dead,no standby,no lights,no output voltages on psu
                  for anyone fixing this set replace regulator "strw6252"a 6 pin device,check vcc to ground, pin 4 and 5 should read open,mine was shorted.
                  also replace "r111" it is marked as a resistor but it is wrong,replace with a 2amp time delay pico fuse,this one goes open circuit due to str6252 vcc and ground going short.
                  tv up and running
                  can this be put in the tv section by any chance?
                  • PeteS in CA
                    • Aug 2005
                    • 3579
                    Multimeter, the "H" is insode an "O", or appears to be, hence my guess that the manufacturer is Otto Heil, which does manufacture fuses. That reference designator is confusing.
                    PeteS in CA
                      They may have used the fusible resistor (<1 Ohm) at the beginning, then it got changed to a fuse instead in the later version of the PCBA.
                      • Viktor Árvai
                        Acer nitro 5 AN517-54-71TL Gh53g-LA-L191P Part identification
                        by Viktor Árvai
                        Hi !
                        I would need some help in part identification , on a GH53G-LA-L191P motherboard , i have downloaded a boardview file from here for LA-L191P there are some difference but essentialy its the same on this file it shows prm6 i would like to know the value of that resistor i think.
                        Thank you !...
                        03-06-2025, 01:28 PM
                      • NConstantinou
                        LENOVO LA-K052P PART IDENTIFICATION PART
                        by NConstantinou
                        Dear all
                        i have tis m/b with an ic mark AWW6SF which i am trying to find datasheet but i couldn't.
                        can someone help!
                        06-02-2025, 07:23 AM
                      • edugimeno
                        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                        by edugimeno
                        Hi There!
                        I'm trying to help my friend who owns a restaurant be just bought.
                        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                        It's stuck using, I guess, the 2 sided tape that comes with the strip
                        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                        09-05-2024, 09:34 AM
                      • G-Sting
                        iPad Pro A1876 SHORT Part Identify Help Needed
                        by G-Sting
                        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                        SO My main concern is what part should i order what should i search the name for ?
                        on Ipad...
                        05-15-2025, 09:30 AM
                      • corrize
                        A funny fuse story – Lumix LX100 II
                        by corrize
                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                        10-19-2023, 09:58 AM
